    Issues with pressure advance since RRF 3.4
    308
    37.9k
    • Heartleander81undefined
      Heartleander81
      Update on my conversion to Klipper.
      At first the corners didn't look any better than with RRF until I came across a post today that refers to extruder smooth time.
      The standard is with Klipper 0.04, which I also use.
      Switched to 0.01 and the corners look awesome.
      In the article it was said that some extruders can not cope with the smooth time and then you have to get smaller. see my pictures.
      With smooth time 0.04
      With smooth time 0.01
      R4ffersundefined Argoundefined 2 Replies Last reply Reply Quote 2
      • R4ffersundefined
        R4ffers @Heartleander81
        @Heartleander81 wow mate what a difference
        Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
        Heartleander81undefined 1 Reply Last reply Reply Quote 0
          Heartleander81 @R4ffers
          @R4ffers oh yes.
          @dc42 is there also something like pressure advance smooth time under RRF? A few clippers have the problem with the high smooth time, but those who have problems are mostly DirectDrive extruder users. Maybe that's an approach you can follow.
          Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Heartleander81
            @Heartleander81 Can you link that article you mention?
            sebkritikelundefined 1 Reply Last reply Reply Quote 0
            • sebkritikelundefined
              sebkritikel @Phaedrux
              @Phaedrux I see some discussions on it at the bottom of Klipper's Kinematics page
              https://www.klipper3d.org/Kinematics.html
              Some other pages of interest
              https://klipper.discourse.group/t/pressure-advance-smooth-time-on-direct-extruders-with-short-filament-path/1971
              https://github.com/Klipper3d/klipper/issues/4442
              richfelker created this issue in Klipper3d/klipper
              closed Pressure advance smoothing induces e-axis position swings that scale with acceleration #4442
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
                dc42 administrators @Heartleander81
                @Heartleander81 said in Issues with pressure advance since RRF 3.4:
                @R4ffers oh yes.
                No, there isn't anything similar. I will look into that Klipper feature.
                The reason I have made no progress on this is that while a number of users seem to think that pressure advance doesn't work as well in RRF 3.4 as it did in 3.3, and I am prepared to believe that there may be a difference because the relevant code had to be rewritten to accommodate input shaping, nobody has been able to provide a simple GCode script and machine settings that demonstrate a difference when input shaping is disabled. That includes me - I have compared RRF 3.3 and RRF 3.4 prints.
                Heartleander81undefined petriheinoundefined CR3Dundefined gnydickundefined camnewnhamundefined 5 Replies Last reply Reply Quote 0
                  Heartleander81 @dc42
                  @Phaedrux
                  I couldn't find any differences between 3.3 and 3.4.x, but I still have a picture of a test where the corners became nice with PA. As now with klipper. The Artikel from sebkritel is that who I read.
                  • Argoundefined
                    Argo @Heartleander81
                    @Heartleander81
                    So altering the smooth time value did improve your corners and PA alone did not?
                    • petriheinoundefined
                      petriheino @dc42
                      Hi folks, my guess is OP simply did finer calibrations after update and found out underlying RRF issues regarding PA, Retraction, Extruder steps and acceleration relation... I got similar results (improvements) with Klipper conversion. I did some testing and posted it here earlier.
                        Heartleander81 @Argo
                        @Argo said in Issues with pressure advance since RRF 3.4:
                        PA alone didn't make the whole corner look nice. See the picture with the corner sticking out in the direction of travel. Only with the change of smooth time and renewed PA, which was then higher, did the corners become so clean.
                        Argoundefined 1 Reply Last reply Reply Quote 1
                        • Argoundefined
                          @Heartleander81
                          I see.
                          I know from another Klipper user that he also only could get nice corners by playing around with the smooth time setting. Pressure advance alone did not help much.
                          Maybe extruders / hotends are so particular nowadays that we need this setting to get nice corners?
                          Here is the example from the user I'm talking about:
                          He has a bowden setup and needed to increase the smooth time in order to get nice corners. PA alone did not the trick.
                          How high are the chances we might get this feature for RRF? I think this might very much help those who are having problems with PA at the moment.
                          Heartleander81undefined 1 Reply Last reply Reply Quote 1
                            @Argo ok. Nice test from him. I find for my Hevort 0.02 smooth time and 0.044 PA. Worked nice. I hope my Info can help Duet.
                            • CR3Dundefined
                              CR3D @dc42
                              @dc42 Hi David,
                              I have to join this conversation because through my contact to @Heartleander81 i noticed this effect with "round corners" at some of our machines to.
                              I think this comes with newer firmware and if you made some changes into PA there would be an issue. But how can we test it that it would be helpfull for you?
                              one of our customers has now contacted us explicitly about this effect and is looking for a solution. I can't compensate for it by increasing the PA value. We've tested a lot here.
                              Thank you 🙂 Regards Christian from @CR3D
                              Christian from CR-3D
                              Homepage:
                              www.cr-3d.de
                              Facebook:
                              https://www.facebook.com/cr3d.official
                              Our Discord Server
                              https://discord.gg/SxRaPNuRdA
                              Thingiverse Profile:
                              https://www.thingiverse.com/cr-3d_official/about
                                dc42 administrators @CR3D
                                @CR3D said in Issues with pressure advance since RRF 3.4:
                                1. Find a print where there is a clear visible difference between the effect of pressure advance (e.g. on corners or infill) between RRF3.3 and RRF3.4.4 with the same configuration for both, and no input shaping when running RRF 3.4.4.
                                2. Edit the GCode file to reduce it to a short print, preferably just 1 or 2 layers.
                                3. Post that file along with your config.g and other relevant macro files.
                                • gnydickundefined
                                  gnydick @dc42
                                  @dc42 why don't you just generate the move list from a 3.3 system and from a 3.4 system for the same gcode and output it to text files and diff them?
                                    dc42 administrators @gnydick
                                    @gnydick said in Issues with pressure advance since RRF 3.4:
                                    Because none of the prints I and others have tried show any difference between 3.3 and 3.4. Nobody has produced a print and machine settings that shows a difference. If somebody ever does, then I will be able to use the method you suggested or another method to see what has changed.
                                    oliofundefined gnydickundefined 2 Replies Last reply Reply Quote 0
                                    • oliofundefined
                                      oliof @dc42
                                      I personally believe that the changes must have happened before 3.3 ... or that the observed issue isnt due to a change in firmware but a change in perception of acceptable corner bulging due to the performance of non-RRF systems.
                                      A decent way to bisect this is to take a Duet2 board, and go back all the way to RRF 2.0.3, and then work through at least 3.0, 3.1.1, 3.2.2, 3.3 to see whether my hypothesis holds.
                                      But I wouldn't ask anyone to lose a week of their life to do this...
                                        dc42 administrators @oliof
                                        @oliof I think you are likely correct. Pressure advance is not a compete solution to corner bulging because there are other factors at play. I have to compensate for one of those other factors separately from PA.
                                        Accuracy of perimeters in general (including reduced corner bulging) is better if you select "External perimeters first" in the slicer. Doing so might make printing steep overhangs more difficult, but I am not aware of any other disadvantages. I have been printing external perimeters first for years.
                                        • gnydickundefined
                                          gnydick @dc42
                                          @dc42 why wait? I would do what I'm suggesting over and over with lots of different gcode files.
                                          In fact, I would make that part of the release process to validate.
                                            jay_s_uk
                                            I've printed test files with 3.2.2, 3.3 and 3.4.4 and have no been able to see a difference
