    Hollow shaft extruder
    345
    40.5k
    • JoergS5undefined
      JoergS5 @o_lampe
      @o_lampe would it be possible to prepare the filament (eg near the filament holder) with grooves in advance, so the requirements are lower for the extruder (only Z movement needs to be exact), or is this patent protected? (I cannot remember the printer name, with special filament gear rod at one side)
      o_lampeundefined tombrazierundefined 2 Replies Last reply Reply Quote 1
      • o_lampeundefined
        o_lampe @JoergS5
        @JoergS5 There are more and more people using push-pull dual extruder motors. If the stationary motor would already cut the thread (with a beefy NEMA17 motor) it would help for sure. Just wondering, if the threaded filament would still fit through common PTFE tube?
        I'm impressed of the pancake motor weighting only 28 grams. It would be a good candidate then (with a hollow shaft)
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @o_lampe
          Guys, this is a can of worms with hollow shaft.
          • o_lampeundefined
            o_lampe @tecno
            @tecno A few years ago, that's what they said about geared extruders, too.
            I see it as a challenge. Maybe we'll end up with a ballscrew-extruder? I've drawn some sketches already 😉
            tecnoundefined pakarundefined 2 Replies Last reply Reply Quote 0
            • tecnoundefined
              tecno @o_lampe
              @o_lampe
              Biggest issue is the hot hollow shaft, not an easy task to solve.
              o_lampeundefined tombrazierundefined 2 Replies Last reply Reply Quote 0
              • o_lampeundefined
                o_lampe @tecno
                @tecno Will it be hotter than the following heatsink?
                Which filament will suffer the most?
                • ABS will even like it to be preheated
                • PETG, I don't know
                • PLA, perhaps above 60°C?
                Maybe we find a 3mm OD PTFE tube that fits inside the shaft? Or cover the inner shaft wall with Kapton tape...
                One step at a time
                nikschaundefined 1 Reply Last reply Reply Quote 0
                • o_lampeundefined
                  o_lampe
                  In the meantime, I sketched ballraces wrapped around filament. (I have a bag of 2.3mm balls for mgn12 maintenance)
                  The races should intersect with the filament at the angled part, but not at the start/endpoint
                  The intersection I achieved looks a bit odd, but i can't figure out how to solve it in openScad.
                  • pakarundefined
                    pakar @o_lampe
                    @o_lampe Check this one.. opensource design with files on github.. Uses a BLDC motor + encoder.
                    Weight is just below 90g.
                    Demo of it in use.
                    https://www.youtube.com/watch?v=f0SuaIMxAs0
                    Assembly video
                    https://www.youtube.com/watch?v=wmcOtlD_yG0
                    o_lampeundefined 2 Replies Last reply Reply Quote 1
                    • tombrazierundefined
                      tombrazier @tecno
                      @tecno It's not a problem if the motor does not get hot and that's ultimately a function of gearing ratio. I have been using a hollow shaft for over a year with no problems at all.
                      • o_lampeundefined
                        o_lampe @pakar
                        @pakar I like that approach with the stepper below the screw part. That would be a good idea on a Smart-Effector, too. If only there weren't so many connectors...
                        A pancake is so short, the filament won't have much time to heat up.
                        pakarundefined 1 Reply Last reply Reply Quote 0
                          tombrazier @JoergS5
                          @JoergS5 said in Hollow shaft extruder:
                          Lining up the groove with the wheels would be tricky. What is most likely to happen is you cut another thread and the excess cutting grinds the filament into dust.
                          And, responding to the question about patents, there is a potential problem here. Fuselabs has a patent which covers the VDE-100 and any variation you can imagine. However for VDE-100 specifically, and perhaps other variations, there is prior art. See https://www.patreon.com/posts/threadless-or-57786089.
                            tombrazier
                            @nikscha Here are some filament photos for you. This piece of filament was fed at a constant 6mm/s. Initially there was no load as it moved through the heatsink. When it hit the nozzle, the load increased rapidly and the thread pitch became compressed.
                            Here is a close-up showing the shape of the groove in profile. As you can just see when the pitch compresses a slight ridge develops parallel to the groove and the groove widens.
                            It's pretty difficult to photograph this, so apologies for the imperfect images.
                            nikschaundefined 1 Reply Last reply Reply Quote 1
                            • mrehorstdmdundefined
                              mrehorstdmd
                              Does the "thread" compression occur because the bearings used to cut them wobble a bit? If you used two wheels to cut threads on each of the 3 positions, and mounted the cutters on a short rod or tube with a bearing at each end, the wobble would go away and so might the thread compression. Or maybe needle bearings would be better than ball bearings for this application.
                              You can get 5mm dia stainless steel tubing via amazon: https://www.amazon.com/uxcell-Stainless-Thickness-Seamless-Straight/dp/B082FGC8XG
                              If you can't drill the motor shaft, I suspect you can press the shaft out of a motor and replace it with a tube without too much difficulty. I think the hot hollow shaft is only a problem if you print with PLA. I can't foresee the future and can't say for sure that my prints will never end up in a hot car for a few minutes, so I prevent problems by not printing with PLA.
                              Slightly off-topic, we went from mostly using 3mm filament to 1.75mm because the extruders could be made smaller and the smaller diameter filament can melt faster. Why aren't we moving to 1mm filament? The reduced diameter would allow melting the filament almost right at the nozzle and a lot of extrusion problems would go away, I think.
                              • o_lampeundefined
                                o_lampe @mrehorstdmd
                                @mrehorstdmd Re: smaller filament
                                I made my own 0.8mm filament a while back. 0.8mm because 1mm ID PTFE tube was available. It would help shrinking extruders and reduce weight.
                                I couldn't test much, because there was no hobbed gear that I could use.
                                The screw extruder would also be difficult to adapt; needs much smaller bearings and so little filament to bite.
                                @deckingman Do you think, mixing extruders would benefit from thinner filament diameter? Toothpaste-effect a.s.o...
                                Talking about making filament: It would be nice to have threaded filament right from the roll.
                                The intake of the extruder would have a matching thread and it rotates with the bearings. So the thread would align automatically .
                                • JoergS5undefined
                                  JoergS5
                                  This post is deleted!
                                    tombrazier @mrehorstdmd
                                    @mrehorstdmd said in Hollow shaft extruder:
                                    I don't think so. It happens with ABEC-5 bearings which have very little play. My best explanation from examining the filament is that the compression is caused by distortion of the plastic.
                                    • CNCModellerundefined
                                      CNCModeller
                                      Has anyone tried a knurled roller rather than a set of "blades"?
                                      Polar Duet3 Mini + 1HCL
                                      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                      Wanhao D4S: Duet2
                                      https://forum.duet3d.com/post/296755
                                      K40 Laser, Duet2
                                      https://forum.duet3d.com/post/312082
                                      Wanhao D5S
                                      https://www.youtube.com/CNCModellerUK
                                      • o_lampeundefined
                                        o_lampe @tombrazier
                                        @tombrazier I don't like to load a ball bearing right at the edge (flange), That's why I proposed the roller with the cutting edge in the middle.
                                        It would also help, if you'd add a supporting disk on top of the bearings to prevent them from getting spread apart.
                                        • o_lampeundefined
                                          o_lampe @CNCModeller
                                          @CNCModeller So far I've read about aluminum-oxide powder coated or sandblasted rollers, metric screws without any ball bearing, flanged bearings and the guy with the brushless motor uses DIY rollers with a fine pitch rounded thread.
                                          A knurled roller (with a criss-cross pattern?) wouldn't cut a thread in the filament. That's similar to the failed sandpaper-rollers, I guess.
                                          tombrazierundefined 1 Reply Last reply Reply Quote 0
                                          • o_lampeundefined
                                            o_lampe @pakar
                                            @pakar I found this guy who forked the project. He uses a smaller brushless motor and added a quick-release system for filament change. Last commit was one year ago, but still a work in progress.
