    Auto pressure advance turning by hotend pressure
    35
    3.0k
    • PenguinAkikoundefined
      PenguinAkiko @nikscha
      @nikscha Bambu Lab tests pa every print, and 50ms really slow, HX711 can reach 80HZ, Prusa using HX717 320HZ, higher the sampling frequency, the more beneficial for auto PA testing.
        PenguinAkiko
        find a better chip for load cell.
        CS1237 http://www.asidesigner.com/Files/PartFiles/15315/222/cs1237_datasheet.pdf
        spi bus 1.28kHz ADC and PGA
          @nikscha Here is a post about sampling speed
          https://forum.duet3d.com/post/251488
            PenguinAkiko
            https://wiki.bambulab.com/en/a1/manual/intro-a1
            PenguinAkikoundefined 1 Reply Last reply Reply Quote 0
              PenguinAkiko @PenguinAkiko
              @penguinya The introduction of bambulab confirmed my guess.
              • Charlieundefined
                Charlie
                Correct me if Im wrong, but I feel like this sensor could also be used for filament runout/jam detection as well. Like if the force expected by feeding the filament is not produced, it could indicate that there is some filament error.
                PenguinAkikoundefined Richard Fundefined 2 Replies Last reply Reply Quote 0
                  PenguinAkiko @Charlie
                  @Charlie Yes prusa has implemented it
                  Charlieundefined MJLewundefined 2 Replies Last reply Reply Quote 0
                  • Richard Fundefined
                    Richard F @Charlie
                    @Charlie would a mouse optical sensor work to monitor filament
                    oliofundefined Charlieundefined 2 Replies Last reply Reply Quote 0
                    • oliofundefined
                      oliof @Richard F
                      @Richard-F that's the simple runout switch that you find on many printers. There are other filament failures you'd want to catch.
                      • Charlieundefined
                        Charlie @PenguinAkiko
                        @penguinya Do you have a link to this? I havent seen anything about it.
                        PenguinAkikoundefined 1 Reply Last reply Reply Quote 1
                        • Charlieundefined
                          Charlie @Richard F
                          @Richard-F It would absolutely work. Ive seen a few systems using this, and Ive used it myself in the past. I know the Duet supports it, though Id recommend looking around to see how others have implemented it. (eg: using printed levers to contact the filament instead of the switch lever contacting the filament directly)
                          Richard Fundefined 1 Reply Last reply Reply Quote 1
                            Richard F @Charlie
                            @Charlie Thanks 🙂
                            Charlieundefined 1 Reply Last reply Reply Quote 0
                            • Charlieundefined
                              Charlie @Richard F
                              @Richard-F Youre welcome. Happy Printing! 🙂
                                PenguinAkiko
                                Just an updating.
                                  @Charlie https://help.prusa3d.com/article/stuck-filament-detection-13101-mk4-21101-mk3-9-17108-xl_690089
                                  • Charlieundefined
                                    @penguinya I love it! I'm assuming that the geometry near the top is to allow for deflection that can be measured using a strain gage.
                                    Random thought though. Would it be necessary to constrain it some other way to prevent loads from being transmitted from the model being printed to the load cell? Like, if you do a travel move, and the nozzle skips along the top of the print, it will transfer load to the load cell. Perhaps this can be mitigated in firmware (by not taking measurements unless its actively extruding) or filtering out certain frequencies.
                                      @Charlie According to the simulation results, the impact on printing is unobservable.
                                      Aluminum 6061, 100N force
                                        @penguinya Just early version, I think it is ok.
                                        • Charlieundefined
                                          @penguinya Cool work! And apologies if I was unclear, but I was thinking that the print itself may induce feedback that may skew how the strain is being determined. Not that the reduced material would affect print quality. But again, that may be able to be filtered out.
                                          • MJLewundefined
                                            MJLew @PenguinAkiko
                                            @penguinya Yes, it's operating on Prusa MK4 and XL, but I had to turn it off on my machine because it was falsely triggering on the first layers when they had low layer height. I suspect that there might need to be some exception incorporated for those circumstances.
                                            They have described it in these release notes.
