    Duet3D announces new tool board at FormNext
    107
    8.8k
    • Surgikillundefined
      Surgikill @deckingman
      @deckingman from the video interview they did they said that this heatsink is the most efficient heatsink they have ever designed, but that doesn't mean it can wick away more heat.
      I'm hoping that the limit is pla printing, but I kind of doubt it. I might be able to get away with 40c chamber temp, but would much rather run at 65. Guess I will just have to use the hemera xs.
        jay_s_uk @Surgikill
        @Surgikill I spoke to E3D about this today. The limitation on the 40 degrees is the motor, nothing else. They will releasing a more capable motor in the new year
        Surgikillundefined 2 Replies Last reply Reply Quote 4
          Surgikill @jay_s_uk
          @jay_s_uk Awesome. Thanks for the heads up. I submitted a support request but haven't heard anything back.
            Surgikill @jay_s_uk
            @jay_s_uk said in Duet3D announces new tool board at FormNext:
            Just to corroborate this, I received this response from e3d today. Hopefully the ht version does release this month.
            Mr.Crispinundefined 1 Reply Last reply Reply Quote 1
            • Mr.Crispinundefined
              Mr.Crispin @Surgikill
              This make you wonder why they (E3D) released a product only to advise they are going to update it a few weeks later, i wonder if early adopters with get an upgrade ?
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @Mr.Crispin
                @Mr-Crispin said in Duet3D announces new tool board at FormNext:
                I think you/we/many are overthinking what most/many use their 3D printers for. Most people using their 3D printer for hobby stuff without an enclosure will probably newer have an issue with a 40C rated DD extruder, since they're probably pushing PLA or PET with it anyways.
                And those of us with enclosued printers pushing ABS, ASA etc. will just have to wait. A larger "issue/challenge" is the torque/accelerantion dropoff the Roto apparently has (based on Thomas Sanladerer's video).
                dc42undefined Surgikillundefined 2 Replies Last reply Reply Quote 2
                • Notepadundefined
                  Notepad
                  Also lets not forget about E3D's design methodology of under promise over deliver.
                  The reason for the 40C recommended limit is going to be a worst case scenario style of limit. where you are running the extruder at max power, on a high flow hot end, on the largest nozzle, in higher than ambient temperatures, with a low temp filament.
                  The real bamboo printer manufacturer
                    dc42 administrators @Exerqtor
                    @Exerqtor said in Duet3D announces new tool board at FormNext:
                    There is speculation in the comments (which Tom hadn't denied when I looked yesterday) that the dropoff at high extrusion rates was caused at least in part by running the extruder in stealthChop mode.
                    Notepadundefined 1 Reply Last reply Reply Quote 5
                      Surgikill @Exerqtor
                      @Exerqtor I'm still waiting on more tests. My money is on the stealthchop issue. Apparently around 300rpm is where the problem arises. I'll do some quick math to see if that is around the 8mm/s where he was experiencing drop off.
                      Surgikillundefined 1 Reply Last reply Reply Quote 2
                      • Notepadundefined
                        Notepad @dc42
                        @dc42 I cant say for certain as I have only tested the preproduction version. But I definitely didn't get the same values as Tom
                          Surgikill @Surgikill
                          @Surgikill said in Duet3D announces new tool board at FormNext:
                          At 300rpm on the motor, the hobbed gear would need to be around 18mm in order to achieve 8mm/s. At 10mm/s it would need to be around 23mm. I'm not sure on the actual size, but I would bet all my money it's less than 18mm, so that motor was going well in excess of 300rpm. Definitely needs more testing.
                          • jchodakowskiundefined
                            jchodakowski
                            Is there any access to the printed mount parts for the Z sensor? I've seen the spacer for the tb but nothing else.
                            • jltxundefined
                              jltx
                              Does the roto toolboard come with scanning z probe coils? I don’t see where to get those separately.
                              elmoretundefined 1 Reply Last reply Reply Quote 0
                              • elmoretundefined
                                elmoret @jltx
                                @jltx Yes
                                • Edkirkundefined
                                  Edkirk
                                  I have ordered the new tool board to install on my Voron Trident with Micro Swiss NG Extruder, E3D hotend using Duet IR Probe for Z probe. I see in the Duet 3 Roto Toolboard documentation under Firmware notes "Compatible RepRapFirmware version 3.5 or later". I updated my 6HC with SBC which only goes up to 3.4.6, is there going to be any problems using 3.4.6 or do I have to wait for 3.5?
                                  I plan on using a Voron Tap Z-Probe with optical sensor (not Duet IR probe I am currently using) then when I have everything working converting the Tap optical to Piezo from Precision Piezo to work like the Delta Smart Effector so the Tap probe will be a true tap probe like the Delta Smart Effector. Does this configuration look like it will work? Thanks, Ed
                                  jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    jay_s_uk @Edkirk
                                    @Edkirk you need to use 3.5. It won't work correctly with 3.4.6
                                      dc42 administrators @Edkirk
                                      @Edkirk you can install 3.5.0-rc.2 if you switch your package feed on the SBC from the stable to the unstable feed.
                                      Edkirkundefined 1 Reply Last reply Reply Quote 0
                                      • Edkirkundefined
                                        Edkirk @dc42
                                        @dc42 Where do I find package feed?
                                        Exerqtorundefined Edkirkundefined 3 Replies Last reply Reply Quote 0
                                        • Exerqtorundefined
                                          Exerqtor @Edkirk
                                          @Edkirk said in Duet3D announces new tool board at FormNext:
                                          Check this out 😊
                                          • Edkirkundefined
                                            Edkirk @Edkirk
                                            This post is deleted!
