    6XD I/O >> Issue solved
    5.3k
      droftarts administrators @tecno
      @tecno Ah, that looks like an RGBW ring. Try
      M950 E0 C"led" Q3000000 T2
      M150 E0 R255 P128 S20 F0
      M950 T2 tells RRF that it's RGBW, not RGB.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @droftarts
        @droftarts
        Same same
        Will change LED ring to one with black PCB board. This a job for torrow 😉
        • tecnoundefined
          tecno @tecno
          @droftarts
          Morning Ian,
          Changed LED strip and only 1 of 8 is working on this one too.
          Any suggestions?
          Cheers
          Bengt
            @tecno I've just tested both RGB and RGBW LEDs on my 6HC, both worked without issue. I've asked someone with a 6XD to test.
            Can you post a link to the white LED ring you bought? And post a picture of the current wiring?
            • tecnoundefined
              tecno @droftarts
              @droftarts
              https://vi.aliexpress.com/item/1005002313192735.html?spm=a2g0o.order_list.order_list_main.11.364b1802NFG3VP&gatewayAdapt=glo2vnm
              Both white and ´blach PCB 8 LEDS
              Wiring https://forum.duet3d.com/post/345489
              gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @tecno
                @tecno Shouldn't the control signal be going to d0 and not to d1?
                • tecnoundefined
                  tecno @gloomyandy
                  @gloomyandy
                  As I understand is 6XD D0 out goes to Di in.
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                    @tecno Those do look like RGB LEDs, looking closer. Though they should light up, just with the wrong colours, if you put the wrong T parameter in M950.
                    I thought you said you had changed the wire over? @tecno said in 6XD I/O >> Issue solved:
                    Change White to shield.
                    On each LED, there is a corner 'notch' to indicate which pin is GND. Can you check continuity of GND, DI and 5V from the LED pins to the connector?
                    @gloomyandy It's DI for Digital In, DO is Digital Out, where it passes the signal on to the next one. Mine are labelled and wired like that.
                      gloomyandy @tecno
                      @tecno This has nothing to do with the 6XD I'm talking about the pads on the LED ring, there is a D0 and a D1. Your wiring here: https://forum.duet3d.com/post/345489 shows it going to D1 I think it should go to D0. It seems very odd to me to have the input labelled D1 and the output labelled D0.
                        gloomyandy @gloomyandy
                        Ah yes that may be Din and Dout I suppose. Oh well good luck!
                        • tecnoundefined
                          tecno @gloomyandy
                          @droftarts
                          So now I changed White to signal and Shield is now 5V
                          So now we are getting closer 🙂
                            @tecno Okay, so now use:
                            M950 E0 C"led" Q3000000 T1
                            ie change T2 to T1
                            I expect that bare 'earth' wire had too much capacitance to transmit the signal. Now you're using the bare wire for 5V, so easier to create a short. Same goes for using that wire for GND. I'd replace the wiring with individually insulated wires, ie 3-core wire. If you don't have 3-core wire, use left-over stepper motor wire, that's about the right gauge for LEDs.
                            • tecnoundefined
                              tecno @droftarts
                              @droftarts
                              Works in R255 and P can be set = Nice.
                              Now to play with new colors
                                @tecno Do all 8 LEDs work now, and are controllable?
                                RGB LEDs aren't the best for white light. You'll have to play around with the levels in M150 for R, U (for green) and B, and brightness (P) to get close to what you want. If it's mostly white you want, you probably should have got RGBW, or just white, LEDs.
                                • tecnoundefined
                                  tecno @droftarts
                                  @droftarts
                                  Yes all 8 work
                                  I am aware that I can not get perfect greyscale with RGB. Hard to find 8leds RGBW that fits.
                                  Thank you very much for your kind help Ian, I owe you a pint or two 🙂
                                  I am sure more questions will arise
                                  Cheers
                                  Bengt
                                  • tecnoundefined
                                    tecno @tecno
                                    • tecnoundefined
                                      tecno @tecno
                                      @droftarts
                                      ;***Outputs
                                      M950 P0 C"out0" ; Q500 ;#1 Nozzle Vacuum
                                      M950 P1 C"out1" ; Q500 ;#2 Nozzle Vacuum
                                      M950 P2 C"out2" ; Q500 ;Drag PIN Actuator
                                      M950 P3 C"out3" ; Q500 ;ENA Nozzle 1/2 Up
                                      M950 P4 C"out4" ; Q500 ;Xross cursor
                                      M950 P5 C"out5" ; Q500 ;LED light x
                                      M950 P6 C"out6" ; Q500 ;Vacuum power
                                      Have problem with Outputs 4 and 5. can not switch off. Any advice is appreciated-
                                      Off=1.4V On=1.3V all other Off 24V On 0V
                                      tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                      • tecnoundefined
                                        tecno @tecno
                                        @droftarts
                                        Is this something we can get working?
                                        There is a cable with RX/TX/GND for the old controller. Two chips for vacuum measurement.
                                        Cheers
                                        Bengt
                                          Was this working before? Have you fixed it? Sounds more like a wiring problem.
                                          What chip is it? You need to find out what signal it outputs, and what signal it expects. If it outputs an analog signal of 0-3.3V, you can probably set it up as an analogue sensor, or a digital sensor if it outputs an on/off signal.
                                          • tecnoundefined
                                            tecno @droftarts
                                            @droftarts
                                            Hello Ian,
                                            These two worked OK with original controller, never got them working with 6XD.
                                            Wires have been checked, but I have to measure continiuity once moore on out 4 and 5.
                                            Have to dismanlte the board and see what is on it.
                                            Bengt
