    PrusaSlicer 2.2 released
    prusaslicer
    18
    46
    1282
    • droftarts
      droftarts administrators last edited by
      New PrusaSlicer 2.2 looks interesting: https://youtu.be/wy3u4DNh_XQ
      Might have to finally wean myself off Cura!
      zapta 1 Reply Last reply Reply Quote 1
      • zapta
        zapta @droftarts last edited by
        @droftarts said in PrusaSlicer 2.2 released:
        Already won me some time ago. Prusa seems to put more emphasis on usability.
        It works well with duet and even has built in wifi upload and start function.
          It's an improvement to be sure, but I find myself missing some of the fine tuning options I get with this Cura build.
          https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0&lst=&preview=README.md
          Fine control of bridging parameters
          Speed and fan control for overhangs
          Fine control over speed accel and jerk for all moves
          Tree supports
          Adjustable fan lag time
          Complete control over Z seam placement
          Modifier meshes and per part settings have a far more usable GUI
          Built in change setting at Z post processor plugin
          Duet upload via plugin
          Slicing and GUI performance is even greatly improved recently. Almost on par with Prusa Slicer.
          Numerous other small tweaks that you simply can do in Slicer
          The only pet peeve I have with Cura is that thin wall printing and gap fill is not as good as Slic3r. It's better in that custom build than the regular build, but it still has some issues.
          zapta 1 Reply Last reply Reply Quote 0
          • Danal
            Danal last edited by
            I've slowly switched from Cura to Slic3rPE.
            I am sometimes forced to use Simplify3D (long story) and have really come to despise it.
            PaulHew 1 Reply Last reply Reply Quote 0
            • zapta
              zapta @Phaedrux last edited by
              @Phaedrux, not commenting on any specific slicer or controller but I think that in general having that many manual controls is an indication of the immature stage of this technology.
              All we need is a single control, to select the color of the printed object. ๐Ÿ˜‰
              Phaedrux 1 Reply Last reply Reply Quote 2
                Phaedrux Moderator @zapta last edited by
                @zapta said in PrusaSlicer 2.2 released:
                I don't think it will ever be as simple as a 2d paper printer. Just look at CNC machining. It's been around for ages and it takes a skilles operator with a specific intention and advanced tools to get good results. And honestly where's the fun in that if it were that easy?
                matt3o 1 Reply Last reply Reply Quote 1
                • deckingman
                  deckingman last edited by
                  Does anyone know of a slicer which has the concept of tools which aren't necessarily extruders? What I mean by that is the slicer needs only to put a Tn command in the gcode file and can otherwise be completely dumb of what that Tn consists of. I still use a very early version is SliC3r which does that. Slic3R PE assumes that all tools must have a single extruder so before I can use say tool 9 which might be orange (a mix of red and yellow) I have to set up 9 extruders in the slicer, even though only 6 physically exist.
                  Come to that, does anyone know of a slicer which has no limit (or a very high one) on the number of tools? I need at least 9.
                  bot 1 Reply Last reply Reply Quote 0
                  • PaulHew
                    PaulHew @Danal last edited by
                    @Danal said in PrusaSlicer 2.2 released:
                    Have to agree, I am now trying to use PrusaSlicer primarily. Works really well on the Railcore and the config bundle JohnOFCII produced is superb.
                    Getting to grips with it for the Ender3 but at least Prusa have included support for it.
                    S3D, could not justify the cost. ยฃ130 per year.
                    My twopence worth!
                    P.
                    RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                    Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                    • matt3o
                      matt3o @Phaedrux last edited by
                      @Phaedrux said in PrusaSlicer 2.2 released:
                      my 2D printer still jams paper...
                      I've read on e3d forums that Prusa is the only slicer able to handle very high flow extrusions (fast movements and/or big nozzles). Can you guys confirm that?
                        I first tried PrusaSlicer two days ago, because I needed to test the new object cancellation facility in RRF, which relies on object labelling. I am impressed by it, and planning to switch over to it from S3D. It has other benefits too, such as the built-in file upload to Duets and support for firmware retraction.
                        droftarts 1 Reply Last reply Reply Quote 2
                        • droftarts
                          droftarts administrators @dc42 last edited by
                          @dc42 said in PrusaSlicer 2.2 released:
                          I was about to ask which slicers support that! Any others?
                          There was a couple of things in the video I liked the look of. The main thing missing, for me, seems to be tree support, but I donโ€™t use it that frequently in Cura.
                          • whosrdaddy
                            whosrdaddy last edited by whosrdaddy
                            Been using prusaslicer/Slic3r PE for years now and has never let me down...
                            Now that we finally have layer pause option with v2.2 it's sad that it only emits M601 but RRF only support M226 for pausing the print.
                            @dc42 can you implement M601 as an alias for M226 in the firmware? ๐Ÿ˜‰
                            droftarts zapta 2 Replies Last reply Reply Quote 0
                            • droftarts
                              droftarts administrators @whosrdaddy last edited by
                              @whosrdaddy I donโ€™t think M601 is defined, so you can make a macro in the sys folder called M601.g which will be called when RRF encounters it in Gcode. Then put M226 in that macro. At least, in theory...
                              • whosrdaddy
                                @droftarts didn't know about that one.
                                Printer is busy printing atm but will test this asap, that would be awesome! ๐Ÿ‘Œ
                                • mrehorstdmd
                                  mrehorstdmd last edited by
                                  I sliced a 42 MB STL file to a 280 MB gcode file a couple days ago and it ran fine on the printer. I've had trouble in the past with slicing very large STL/gcode files, so they must have fixed something.
                                  oliof 1 Reply Last reply Reply Quote 0
                                  • droftarts
                                    @whosrdaddy from the video, I thought you could put any Gcode in at a particular layer? Havenโ€™t watched it again, though.
                                    whosrdaddy 1 Reply Last reply Reply Quote 0
                                    • zapta
                                      zapta @matt3o last edited by
                                      @matt3o said in PrusaSlicer 2.2 released:
                                      Please post your config.h file.
                                      • zapta
                                        zapta @whosrdaddy last edited by
                                        @whosrdaddy said in PrusaSlicer 2.2 released:
                                        I saw the announcement about this feature. Previous version had an easy to use pause at layer option that worked very well for me.
                                        I just move the vertical layer slider to the layer I want and click on the [+] icon next to the slider. The printer then pauses at that layer, and you can change filament or just resume with same filament.
                                        • whosrdaddy
                                          whosrdaddy @droftarts last edited by
                                          @droftarts Lol now that you say it, indeed you can. I was too focused on the "pause" thing ๐Ÿ˜‰
                                          • oliof
                                            oliof @mrehorstdmd last edited by
                                            @mrehorstdmd they did significant changes to their movement planner. Maybe that helped.
                                            <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                                            mrehorstdmd 1 Reply Last reply Reply Quote 0
                                            • zapta
                                              zapta @PaulHew last edited by
                                              @PaulHew said in PrusaSlicer 2.2 released:
                                              S3D is in decline, both the company and the product. I have a paid license but I now prefer the free slicers.
                                              You can get some insight on how the company operates here: https://www.glassdoor.com/Reviews/Simplify3D-Reviews-E1187369.htm
                                              (They could learn a thing or two from Duet3d which is smaller but is more productive and provides much better customer support.)
                                              • mrehorstdmd
                                                mrehorstdmd @oliof last edited by
                                                @oliof so it seems!
                                                • Turbo
                                                  Turbo last edited by
                                                  It's now my go to slicer instead of Cura, but there's one major issue for me and thats how it handles dual extrusion. Ill set it to extruder 2 and it'll heat up extruder 1, and when 1 heats up, it tries to extrude out of heater 2. I have to manually heat up extruder 2 before sending it gcode, otherwise things aren't pretty
                                                  Cant stop tuning wont stop tuning.
                                                  Dbot, Custom i3, Voron 0&2
                                                  Danal 1 Reply Last reply Reply Quote 0
                                                  • Danal
                                                    Danal @Turbo last edited by
                                                    @Turbo said in PrusaSlicer 2.2 released:
                                                    Hmmm... I'm running SlicerPE output into a toolchanging printer with no editing of the G-Code. Everything heats just fine. Hmmm...
                                                    Do you have "wait for temp" g-code in your TPOST macros?
                                                    Turbo 1 Reply Last reply Reply Quote 0
                                                    • Turbo
                                                      Turbo @Danal last edited by
                                                      @Danal Is that within prusaslicer or the firmware? never used dual extrusion before and i half expected it to just insert t0/t1/etc into the gcode. i open up a thread about it:
                                                      My Post
