    hbot homes correctly but prints mirrored ,
    8.8k
      You're on the right track. On a cartesian printer it's easy because it's one motor and direction per axis. With corexy there is motor direction of rotation and also which motor is connected to which driver that also matters.
      The movement test in the link isolates each motor so you can see which direction it's going by itself and then from the results it tells you what to change.
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @Phaedrux
        @Phaedrux
        So from your link is way to fix is ?
        If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
        My head hurts !!! Brain Overload !!!!
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        tracarundefined 1 Reply Last reply Reply Quote 0
        • tracarundefined
          tracar @peter247
          @peter247 brain overload x2
            M569 P0 S0 ; X motor runs forwards
            M569 P1 S0 ; Y motor runs forwards
            Set that first.
            Test for the correct X motor movement by sending these commands from the console:
            G91
            G1 S2 X10 F3000
            If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
            When you have the X motor moving correctly, test the Y motor by sending from the console:
            G91
            G1 S2 Y10 F3000
            If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
            Y+ meaning to the back
            • peter247undefined
              peter247 @tracar
              @tracar
              You do need to change the Y homing files , but I think you may have to play to get the direction correct.
              Don't forget to invert all the moves or the G1 Y5 F800 will push it into the end stop.
                The homing direction for Y should be positive direction to the endstop at the rear.
                • tracarundefined
                  tracar @Phaedrux
                  @Phaedrux said in hbot homes correctly but prints mirrored ,:
                  im not using the built in drivers , all are external
                  my config is currently this for x and y:
                  M569 P5 S1 T5 R1 ; physical drive x goes forwards
                  M569 P6 S1 T5 R1 ; physical drive y goes forwards
                    Phaedrux Moderator @tracar
                    @tracar said in hbot homes correctly but prints mirrored ,:
                    Ok, well the idea is that you're setting the motors to rotate in a forward direction, however you do that. I believe that would make it clockwise.
                    • tracarundefined
                      tracar
                      i have set to this
                      M569 P5 S0 T5 R1 ; physical drive x goes forwards
                      M569 P6 S0 T5 R1 ; physical drive y goes forwards
                      the
                      G91
                      G1 S2 X10 F3000
                      they both move towards the back left corner (where the endstops are )
                      so x moves in a negative and y in a positive
                        So swap your X and Y motor plugs.
                        • tracarundefined
                          tracar
                          changed drives to :
                          M584 X6 Y5 Z7:8 E3 ; set drive mapping
                          now with
                          G91
                          G1 S2 X10 F3000
                          x and y move to the negative. so heading x to 0 and y to 0
                          which is the front left side of the printer.
                            If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. Or in your case, flip the direction on your external stepper for the P0 driver, labeled as X.
                            Actually that might be wrong because you've now remapped which driver X is assigned to. You're now using driver 6? Flip that one.
                            • tracarundefined
                              tracar
                              M569 P5 S0 T5 R1 ; physical drive y goes forwards
                              M569 P6 S1 T5 R1 ; physical drive x goes forwards
                              both move in a positive , to the top right side of the printer
                                Move on to the next direction move test.
                                G91
                                G1 S2 Y10 F3000
                                • tracarundefined
                                  tracar
                                  x pos
                                  y neg
                                    Alright, so now when you jog the print head normally, does +x go to the right and Y+ to the back?
                                    Have you changed your homing files to move to Y positive?
                                    • tracarundefined
                                      tracar
                                      jogging is correct
                                      y homing needs to be reversed
                                      • peter247undefined
                                        peter247 @Phaedrux
                                        @Phaedrux
                                        There is also some positive move need to go minus , eg the back off the end stop move , or they will push into the back stop instead of backing off.
                                        So like I said don't change invert all y moves.
                                        • tracarundefined
                                          tracar
                                          homeall works
                                          homex ,and homey work
                                          and......x y jog work in the right way
                                          • peter247undefined
                                            peter247 @tracar
                                            @tracar
                                            So all you need to do now is set the Z offset ?
