    hbot homes correctly but prints mirrored ,
    8.8k
    • peter247undefined
      peter247 @tracar
      @tracar
      I can't see anything wrong with the set ups .
      if you had a Maestro that needs to be set up differently , but you are running a duet 2 wifi , so that doesn't wash .
      Can only think it's wiring ?
      • tracarundefined
        tracar
        it works if i downgrade firmware
        peter247undefined 1 Reply Last reply Reply Quote 0
        • peter247undefined
          peter247 @tracar
          @tracar
          what is your full zprobe config
          have you removed the M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          tracarundefined 1 Reply Last reply Reply Quote 0
          • tracarundefined
            tracar @peter247
            @peter247
            M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
            G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
            M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between points
            • peter247undefined
              peter247 @tracar
              @tracar
              comment out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
              Notes - RepRapFirmware 3
              The F parameter is no longer supported. Use M950 to set the frequency in the M950 command that you use to define the heater .
              The I2 parameter is no longer supported, and I3 does the same as I1. You can use M950 to invert the output.
              You can no longer disable a heater using M307 A-1 C-1 D-1. To use the pin for something else, don't create a heater on that pin.
              • tracarundefined
                tracar
                wiring is all good, as i said it works if i downgrade the firmware,
                something in the settings..............
                  Can you put up your full config.g?
                  peter247undefined tracarundefined 2 Replies Last reply Reply Quote 0
                  • peter247undefined
                    peter247 @Phaedrux
                    This post is deleted!
                    • peter247undefined
                      peter247 @tracar
                      @tracar
                      have you commented out M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                        Phaedrux Moderator @peter247
                        @peter247 said in hbot homes correctly but prints mirrored ,:
                        M307 H7 A-1 C-1 D-1
                        Will just be ignored in RRF3.
                        If you send M98 P"config.g" do you get any errors echoed back?
                        • tracarundefined
                          tracar @Phaedrux
                          @Phaedrux
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Aug 25 2020 08:01:23 GMT-0600 (Mountain Daylight Time)
                          G31 X0 Y0 Z0 P25
                          M550 P"Duet2" ; set printer name
                          M669 K1 ; select CoreXY mode
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M569 P5 S0 T5 R1 ; physical drive y goes forwards
                          M569 P6 S1 T5 R1 ; physical drive x goes forwards
                          M569 P7 S1 T5 R1 ; physical drive z goes forwards
                          M569 P8 S1 T5 R1 ; physical drive z2 goes forwards
                          M569 P3 S1 ; physical drive extruder goes forwards
                          M584 X6 Y5 Z7:8 E3 ; set drive mapping
                          M92 X200.00 Y200.00 Z200.00 E138.23 ; set steps per mm
                          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X25000.00 Y25000.00 Z2500.00 E2400.00 ; set maximum speeds (mm/min)
                          M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X440 Y535 Z900 S0 ; set axis maxima
                          M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
                          M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
                          M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop
                          ;M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                          • tracarundefined
                            tracar @Phaedrux
                            @Phaedrux said in hbot homes correctly but prints mirrored ,:
                            M98 P"config.g"
                            M98 P"config.g"
                            HTTP is enabled on port 80
                            FTP is disabled
                            TELNET is disabled
                            Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                              Phaedrux Moderator @tracar
                              Try enabling the pullup resistor on the servo pin with the ^ before the pin name.
                              M950 S0 C"^exp.heater7" ; create servo pin 0 for BLTouch with pullup
                              • tracarundefined
                                tracar @Phaedrux
                                @Phaedrux
                                nada.
                                  Try M950 S0 C"exp.31" ; create servo pin 0 for BLTouch
                                  • tracarundefined
                                    tracar @Phaedrux
                                    @Phaedrux
                                    no change
                                    • peter247undefined
                                      peter247 @tracar
                                      @tracar
                                      how are you testing that it is working ?
                                      tracarundefined 1 Reply Last reply Reply Quote 1
                                      • tracarundefined
                                        tracar @peter247
                                        @peter247
                                        make the changes to config file, save ,reset board send command M280 P0 S10
                                        peter247undefined 1 Reply Last reply Reply Quote 1
                                          Does it do a self test on bootup?
                                          • tracarundefined
                                            tracar @Phaedrux
                                            @Phaedrux
                                            yes
