    Duet3D announces new tool board at FormNext
    107
    8.8k
      dc42 administrators @Exerqtor
      @Exerqtor said in Duet3D announces new tool board at FormNext:
      And those of us with enclosued printers pushing ABS, ASA etc. will just have to wait. A larger "issue/challenge" is the torque/accelerantion dropoff the Roto apparently has (based on Thomas Sanladerer's video).
      There is speculation in the comments (which Tom hadn't denied when I looked yesterday) that the dropoff at high extrusion rates was caused at least in part by running the extruder in stealthChop mode.
      Notepadundefined 1 Reply Last reply Reply Quote 5
      • Surgikillundefined
        Surgikill @Exerqtor
        @Exerqtor I'm still waiting on more tests. My money is on the stealthchop issue. Apparently around 300rpm is where the problem arises. I'll do some quick math to see if that is around the 8mm/s where he was experiencing drop off.
        Surgikillundefined 1 Reply Last reply Reply Quote 2
        • Notepadundefined
          Notepad @dc42
          @dc42 I cant say for certain as I have only tested the preproduction version. But I definitely didn't get the same values as Tom
          The real bamboo printer manufacturer
            Surgikill @Surgikill
            @Surgikill said in Duet3D announces new tool board at FormNext:
            At 300rpm on the motor, the hobbed gear would need to be around 18mm in order to achieve 8mm/s. At 10mm/s it would need to be around 23mm. I'm not sure on the actual size, but I would bet all my money it's less than 18mm, so that motor was going well in excess of 300rpm. Definitely needs more testing.
            • jchodakowskiundefined
              jchodakowski
              Is there any access to the printed mount parts for the Z sensor? I've seen the spacer for the tb but nothing else.
              • jltxundefined
                jltx
                Does the roto toolboard come with scanning z probe coils? I don’t see where to get those separately.
                elmoretundefined 1 Reply Last reply Reply Quote 0
                • elmoretundefined
                  elmoret @jltx
                  @jltx Yes
                  • Edkirkundefined
                    Edkirk
                    I have ordered the new tool board to install on my Voron Trident with Micro Swiss NG Extruder, E3D hotend using Duet IR Probe for Z probe. I see in the Duet 3 Roto Toolboard documentation under Firmware notes "Compatible RepRapFirmware version 3.5 or later". I updated my 6HC with SBC which only goes up to 3.4.6, is there going to be any problems using 3.4.6 or do I have to wait for 3.5?
                    I plan on using a Voron Tap Z-Probe with optical sensor (not Duet IR probe I am currently using) then when I have everything working converting the Tap optical to Piezo from Precision Piezo to work like the Delta Smart Effector so the Tap probe will be a true tap probe like the Delta Smart Effector. Does this configuration look like it will work? Thanks, Ed
                    jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      jay_s_uk @Edkirk
                      @Edkirk you need to use 3.5. It won't work correctly with 3.4.6
                        dc42 administrators @Edkirk
                        @Edkirk you can install 3.5.0-rc.2 if you switch your package feed on the SBC from the stable to the unstable feed.
                        Edkirkundefined 1 Reply Last reply Reply Quote 0
                        • Edkirkundefined
                          Edkirk @dc42
                          @dc42 Where do I find package feed?
                          Exerqtorundefined Edkirkundefined 3 Replies Last reply Reply Quote 0
                          • Exerqtorundefined
                            Exerqtor @Edkirk
                            @Edkirk said in Duet3D announces new tool board at FormNext:
                            Check this out 😊
                            • Edkirkundefined
                              Edkirk @Edkirk
                              This post is deleted!
                              • Edkirkundefined
                                Edkirk @Edkirk
                                • Edkirkundefined
                                  Edkirk @Edkirk
                                  • Edkirkundefined
                                    Edkirk @Edkirk
                                    • Edkirkundefined
                                      Edkirk
                                      New Duet3D tool board up and running on Voron Trident, with Tap on Z axis for homing and bed leveling. Micro Swiss NG extruder, E3d heater and nozzle.20240109_053911.jpg
                                      • Edkirkundefined
                                        Edkirk
                                        Are there plans for a Delta Smart Effector with built-in Tool Board, I would install on my Delta?
                                        demonio669undefined 1 Reply Last reply Reply Quote 0
                                        • demonio669undefined
                                          demonio669 @Edkirk
                                          @Edkirk +1 I also want this board!!
                                            dc42 administrators @demonio669
                                            @demonio669 @Edkirk please see https://forum.duet3d.com/topic/34657/combined-smart-effector-and-tool-board-for-delta-printers.
