    Dual Z tilts after time (fast)
    22
    840
    • AS-3D Druckundefined
      AS-3D Druck
      Hey there Guys,
      i've got a Problem the keeps me from getting a flat leveled Bed. 😞
      Bild Text
      I've got on the left and on the right an Dual-Leadscre Setup (D-Bot = https://www.thingiverse.com/thing:1001065)
      but it tilts from time to time and i don't know what i should do to prevent that.
      It would be cool if the printer checks the left and the right side and moves both stepper motors independently to adjust those tilting.
      Or is there a other Solution?
      Best regards
      AS-3D Druck / Andre
      • fcwiltundefined
        fcwilt
        The firmware can do what you are asking about.
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
          AS-3D Druck
          Thx, but does it work also if i connected both to the Z?
          I thought i need that Expansion Board for a "second" Z Axis.
          Best regards
          AS-3D Druck / Andre
          aidarundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
          • aidarundefined
            aidar @AS-3D Druck
            @AS-3D-Druck said in Dual Z tilts after time (fast):
            No it does not.
            You can use free driver on Duet, if you have one. Means for example, if you have only one extruder, connected to E0, then you can use E1 for second Z axis motor.
              deckingman @AS-3D Druck
              @AS-3D-Druck The reason why it tilts is because every time you apply power, the motors jump to the nearest full step which might be either forwards or backwards. Actually, I believe it's worse than that and it might actually be a difference of 4 full steps but I can't remember the reason why.
              You have two practical options that I can think of. The first is to drive each motor independently and use bed levelling but as @aidar has pointed out, for that to happen each motor has to be connected to a separate driver. The second option would be to drive both screws together via a single motor and continuous belt.
                dc42 administrators @deckingman
                @deckingman said in Dual Z tilts after time (fast):
                Or stick with 2 motors, but connect them with a belt. The belt needs to prevent one motor moving by 4 full steps relative to the other.
                • jens55undefined
                  jens55
                  Would you not get 'wind up' of the mechanics if you have two motors connected like that?
                  deckingmanundefined 1 Reply Last reply Reply Quote 1
                    deckingman @jens55
                    @jens55 said in Dual Z tilts after time (fast):
                    I would have thought so but perhaps it might not be significant?
                      AS-3D Druck
                      Ok i tryed the independent Leadscrews but it looks like 1mm correction isn't enough. 😲
                      	G32 Error: Some computed corrections exceed configured limit of 1.00mm: -2.080 2.814
                      Best regards
                      AS-3D Druck / Andre
                      • Vetiundefined
                        Veti
                        see
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
                        S parameter
                        AS-3D Druckundefined 1 Reply Last reply Reply Quote 1
                          AS-3D Druck @Veti
                          @Veti Thx i tryed 5mm now and it works.
                          From now on i should use in my start Gcode before every Print G32 S2 right?
                          Best regards
                          AS-3D Druck / Andre
                          • Vetiundefined
                            Veti @AS-3D Druck
                            it depends on your bed.
                            if its perfectly flat yes.
                            if not use
                            G32 followed by G29
                              AS-3D Druck
                              Ok i don't know what happend but now my Homing has flipped from front left to back right. (Stall Detection)
                              I don't know why it worked yesterday and now not.
                              Best regards
                              AS-3D Druck / Andre
                              • Vetiundefined
                                Veti
                                do the normal moves are in the correct direction?
                                if yes -> check your homing file moves
                                if no -> change direction of motors in the config
                                  AS-3D Druck
                                  This is how it homes
                                  This is how i home all:
                                  ; Lift Z relative to current position
                                  G91
                                  G1 Z10 F6000 S2
                                  G90
                                  M913 X50 Y50						; reduce motor current to 50% to prevent belts slipping
                                  G91							; use relative positioning
                                  ; X
                                  G1 S1 X-500 F4000					; move the X to max until it detects the min Point
                                  G92 X0							; set X min Point
                                  G1 S1 X30						; move X away from min Point
                                  M400
                                  ; Y
                                  G1 S1 Y-500 F4000					; move the X to max until it detects the min Point
                                  G92 Y0							; set X min Point
                                  G1 S1 Y30						; move X away from min Point
                                  G90							; back to absolute positioning
                                  M913 X100 Y100 Z100					; motor currents back to normal
                                  ; Z
                                  G1 S1 X168 Y95 F2000 					; put head over the centre of the bed, or wherever you want to probe
                                  G30            			    			; lower head, stop when probe triggered and set Z to trigger height
                                  G91                					; relative mode
                                  G1 Z10 F6000 S2       					; raise head 4mm to ensure it is above the Z probe trigger height
                                  G90                					; back to absolute mode
                                  config: https://pastebin.com/gFtv1wM7
                                  Best regards
                                  AS-3D Druck / Andre
                                    @AS-3D-Druck Do the motors still move in the right correct directions? i.e. when you do G1 S1 X-500, does it still move to the left? And when you do G1 S1 Y-500, does it still move to the front?
                                    AS-3D Druckundefined 1 Reply Last reply Reply Quote 0
                                      AS-3D Druck @deckingman
                                      It does not move at all in - only in+ but there is no room for any Movement so it cares in the Extrusion.
                                      The coordinates are set wrong for some reason 😵
                                      btw. i added on my Post before the config.g
                                      Best regards
                                      AS-3D Druck / Andre
                                      • NitroFreakundefined
                                        NitroFreak
                                        You might want to consider joining the two leadscrews with a belt
                                        • Vetiundefined
                                          Veti
                                          this does not answer the question.
                                          move the extruder to the middle
                                          issue M564 H0
                                          and see if the movement are as expeded.
                                          ie x - goes left x+ goes right
                                            AS-3D Druck @Veti
                                            @Veti No it does nit everything in - isn't working except i use M564 H0 than i can manualy move it to the middle but homing does still not work anymore.
                                            Best regards
                                            AS-3D Druck / Andre
