Dual Z tilts after time (fast)
22
797
    AS-3D Druck
    Hey there Guys,
    i've got a Problem the keeps me from getting a flat leveled Bed. 😞
    Bild Text
    I've got on the left and on the right an Dual-Leadscre Setup (D-Bot = https://www.thingiverse.com/thing:1001065)
    but it tilts from time to time and i don't know what i should do to prevent that.
    It would be cool if the printer checks the left and the right side and moves both stepper motors independently to adjust those tilting.
    Or is there a other Solution?
    Best regards
    AS-3D Druck / Andre
      fcwilt
      The firmware can do what you are asking about.
      https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        AS-3D Druck
        Thx, but does it work also if i connected both to the Z?
        I thought i need that Expansion Board for a "second" Z Axis.
        Best regards
        AS-3D Druck / Andre
        undefined undefined 2 Replies Last reply 14 Dec 2019, 16:30 Reply Quote 0
          aidar @AS-3D Druck
          @AS-3D-Druck said in Dual Z tilts after time (fast):
          No it does not.
          You can use free driver on Duet, if you have one. Means for example, if you have only one extruder, connected to E0, then you can use E1 for second Z axis motor.
            deckingman @AS-3D Druck
            @AS-3D-Druck The reason why it tilts is because every time you apply power, the motors jump to the nearest full step which might be either forwards or backwards. Actually, I believe it's worse than that and it might actually be a difference of 4 full steps but I can't remember the reason why.
            You have two practical options that I can think of. The first is to drive each motor independently and use bed levelling but as @aidar has pointed out, for that to happen each motor has to be connected to a separate driver. The second option would be to drive both screws together via a single motor and continuous belt.
            undefined 1 Reply Last reply 14 Dec 2019, 17:05 Reply Quote 1
              dc42 administrators @deckingman
              @deckingman said in Dual Z tilts after time (fast):
              Or stick with 2 motors, but connect them with a belt. The belt needs to prevent one motor moving by 4 full steps relative to the other.
                jens55
                Would you not get 'wind up' of the mechanics if you have two motors connected like that?
                undefined 1 Reply Last reply 14 Dec 2019, 17:16 Reply Quote 1
                  deckingman @jens55
                  @jens55 said in Dual Z tilts after time (fast):
                  I would have thought so but perhaps it might not be significant?
                    AS-3D Druck
                    Ok i tryed the independent Leadscrews but it looks like 1mm correction isn't enough. 😲
                    	G32 Error: Some computed corrections exceed configured limit of 1.00mm: -2.080 2.814
                    Best regards
                    AS-3D Druck / Andre
                      Veti
                      see
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M671_Define_positions_of_Z_leadscrews_or_bed_levelling_screws
                      S parameter
                      undefined 1 Reply Last reply 14 Dec 2019, 20:40 Reply Quote 1
                        AS-3D Druck @Veti
                        @Veti Thx i tryed 5mm now and it works.
                        From now on i should use in my start Gcode before every Print G32 S2 right?
                        Best regards
                        AS-3D Druck / Andre
                        undefined 1 Reply Last reply 14 Dec 2019, 20:45 Reply Quote 0
                          Veti @AS-3D Druck
                          it depends on your bed.
                          if its perfectly flat yes.
                          if not use
                          G32 followed by G29
                            AS-3D Druck
                            Ok i don't know what happend but now my Homing has flipped from front left to back right. (Stall Detection)
                            I don't know why it worked yesterday and now not.
                            Best regards
                            AS-3D Druck / Andre
                              Veti
                              do the normal moves are in the correct direction?
                              if yes -> check your homing file moves
                              if no -> change direction of motors in the config
                                AS-3D Druck
                                This is how it homes
                                This is how i home all:
                                ; Lift Z relative to current position
                                G91
                                G1 Z10 F6000 S2
                                G90
                                M913 X50 Y50 ; reduce motor current to 50% to prevent belts slipping
                                G91 ; use relative positioning
                                ; X
                                G1 S1 X-500 F4000 ; move the X to max until it detects the min Point
                                G92 X0 ; set X min Point
                                G1 S1 X30 ; move X away from min Point
                                M400
                                ; Y
                                G1 S1 Y-500 F4000 ; move the X to max until it detects the min Point
                                G92 Y0 ; set X min Point
                                G1 S1 Y30 ; move X away from min Point
                                G90 ; back to absolute positioning
                                M913 X100 Y100 Z100 ; motor currents back to normal
                                ; Z
                                G1 S1 X168 Y95 F2000 ; put head over the centre of the bed, or wherever you want to probe
                                G30 ; lower head, stop when probe triggered and set Z to trigger height
                                G91 ; relative mode
                                G1 Z10 F6000 S2 ; raise head 4mm to ensure it is above the Z probe trigger height
                                G90 ; back to absolute mode
                                config: https://pastebin.com/gFtv1wM7
                                Best regards
                                AS-3D Druck / Andre
                                undefined 1 Reply Last reply 15 Dec 2019, 12:13 Reply Quote 0
                                  @AS-3D-Druck Do the motors still move in the right correct directions? i.e. when you do G1 S1 X-500, does it still move to the left? And when you do G1 S1 Y-500, does it still move to the front?
                                  undefined 1 Reply Last reply 15 Dec 2019, 12:19 Reply Quote 0
                                    AS-3D Druck @deckingman
                                    It does not move at all in - only in+ but there is no room for any Movement so it cares in the Extrusion.
                                    The coordinates are set wrong for some reason 😵
                                    btw. i added on my Post before the config.g
                                    Best regards
                                    AS-3D Druck / Andre
                                      NitroFreak
                                      You might want to consider joining the two leadscrews with a belt
                                        Veti
                                        this does not answer the question.
                                        move the extruder to the middle
                                        issue M564 H0
                                        and see if the movement are as expeded.
                                        ie x - goes left x+ goes right
                                        undefined 1 Reply Last reply 15 Dec 2019, 16:47 Reply Quote 0
                                          AS-3D Druck @Veti
                                          @Veti No it does nit everything in - isn't working except i use M564 H0 than i can manualy move it to the middle but homing does still not work anymore.
                                          Best regards
                                          AS-3D Druck / Andre
                                          undefined 1 Reply Last reply 15 Dec 2019, 16:57 Reply Quote 0
                                          9 out of 22
