    closed loop nema 17/23 driver/controller for Duet 3 6hc board
    47
    3.6k
      @supertb1 we are testing with Nema 17 and Nema 34 steppers with built-in encoders from StepperOnline. Price will be higher than a tool board but I expect it to be lower than a 3HC. We will also offer an optional magnetic encoder + magnet to go on the back of a standard stepper motor.
      chernogorskyundefined MaxGyverundefined supertb1undefined 3 Replies Last reply Reply Quote 1
      • chernogorskyundefined
        chernogorsky @dc42
        @dc42 set it to preorder somethere %-) willing to put some buks there
        supertb1undefined 1 Reply Last reply Reply Quote 1
        • MaxGyverundefined
          MaxGyver @dc42
          @dc42 said in closed loop nema 17/23 driver/controller for Duet 3 6hc board:
          This is amazing! I was already looking into ways to add encoders to my Bondtech LGX extruders. Thank you for your hard work!
          • supertb1undefined
            supertb1 @chernogorsky
            @chernogorsky I agree, I would be willing to put some money on this for pre-order.
              dc42 administrators @supertb1
              https://twitter.com/Escher3D/status/1415953189145399297?s=20
              CNCModellerundefined gregsaunundefined tristanryerparkeundefined 3 Replies Last reply Reply Quote 2
              • CNCModellerundefined
                CNCModeller @dc42
                @dc42 all good progress. Looking forward to getting my hands on one!
                Polar Duet3 Mini + 1HCL
                https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                Wanhao D4S: Duet2
                https://forum.duet3d.com/post/296755
                K40 Laser, Duet2
                https://forum.duet3d.com/post/312082
                Wanhao D5S
                https://www.youtube.com/CNCModellerUK
                • gregsaunundefined
                  gregsaun @dc42
                  @dc42 Awesome news, thank you and congrats to Louis as well!
                  github.com/gregsaun - Papa Bear
                  • tristanryerparkeundefined
                    tristanryerparke @dc42
                    @dc42 Hey David,
                    What kind of current rating are you thinking for these boards?
                    Tristan
                      dc42 administrators @tristanryerparke
                      @tristanryerparke said in closed loop nema 17/23 driver/controller for Duet 3 6hc board:
                      @dc42 Hey David,
                      Tristan
                      Up to 6.3A peak (4.5A RMS) @ up to 50V.
                      We have the new hardware prototypes running now.
                      3DPMicroundefined 1 Reply Last reply Reply Quote 1
                      • 3DPMicroundefined
                        3DPMicro @dc42
                        I am adding cnc capabilities to a manual Lathe at work and was intending to use 2, 4'ish amp Closed loop Nema 23's from Stepperonline and a Duet 2 with expansion board for control. After reading this I would much rather use a MB6HC and the new expansion board. If I could get my hands on one of your new prototypes that would be great. Please let me know if you are interested in dedicating a board for cnc testing. I can be ready in as little as 3 weeks
                        Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                          dc42 administrators @3DPMicro
                          @3dpmicro depending on what else you want to drive, it is may be that a Duet 3 Mini + the closed loop boards would be sufficient for your system.
                          3DPMicroundefined 1 Reply Last reply Reply Quote 0
                          • 3DPMicroundefined
                            3DPMicro @dc42
                            Not much else. Spindle control at some point. I can see how the MB6HC would be a bit overkill for the application.
                            • supertb1undefined
                              supertb1 @dc42
                              @dc42 Hello dc42, it is that time of the month and I am as excited as I have been to take part in field testing the new closed loop controller and steppers. How close is Duet3D to coming to market? As always best regards.
                                @supertb1 we'll be starting the beta test phase shortly.
                                martin7404undefined supertb1undefined Luke'sLaboratoryundefined tristanryerparkeundefined CNCModellerundefined 5 Replies Last reply Reply Quote 2
                                • martin7404undefined
                                  martin7404 @dc42
                                  @dc42 I am interested to test, willing to pay for the hardware
                                  Muldex IDEX Duet2+Duex5
                                  Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                  Sapphire Pro with Duet2, with closed-loop motors
                                  custom high temp E3D tool changer with Duet2+Duex
                                  • supertb1undefined
                                    supertb1 @dc42
                                    @dc42 I'm with Martin7404
                                    • Luke'sLaboratoryundefined
                                      Luke'sLaboratory @dc42
                                      Sounds neat. What MCU do they use?
                                      I'm definitely in for beta, if you're looking for volunteers. I have machines that are heavily EMF-limited at 325mm/s+, have stepper analyzers, and run 15k accel. I'll make sure they get the hot supper they deserve, and finally max out my Magnum+ with a .4mm nozzle. 🙂
                                      Luke
                                      Luke
                                      http://lukeslab.online
                                      MaxGyverundefined 1 Reply Last reply Reply Quote 0
                                      • MaxGyverundefined
                                        MaxGyver @Luke'sLaboratory
                                        I have a professional IDEX printer prepared for closed loop with Nanotech motors featuring integrated encoders. Since all the cabling is already in place, only the closed loop controllers are missing... I would be very happy to support the beta testing.
                                        -Max
                                          @dc42 I would also like to join the beta crew, and would purchase several once everything is refined.
                                          Thanks
                                            CNCModeller @dc42
                                            Great news! I assume the intern? has had fun getting the code up and running 🙂
                                            I'd be interested in taking part in the beta as well.
                                            Looking forward to seeing how hard I can push the polar printer bed!
                                            Wanhao D4S: Duet2
                                            K40 Laser, Duet2
                                            Wanhao D5S
