    closed loop nema 17/23 driver/controller for Duet 3 6hc board
    47
    3.6k
    • chernogorskyundefined
      chernogorsky @dc42
      @dc42 set it to preorder somethere %-) willing to put some buks there
      supertb1undefined 1 Reply Last reply Reply Quote 1
      • MaxGyverundefined
        MaxGyver @dc42
        @dc42 said in closed loop nema 17/23 driver/controller for Duet 3 6hc board:
        We will also offer an optional magnetic encoder + magnet to go on the back of a standard stepper motor.
        This is amazing! I was already looking into ways to add encoders to my Bondtech LGX extruders. Thank you for your hard work!
        • supertb1undefined
          supertb1 @chernogorsky
          @chernogorsky I agree, I would be willing to put some money on this for pre-order.
            dc42 administrators @supertb1
            https://twitter.com/Escher3D/status/1415953189145399297?s=20
            CNCModellerundefined gregsaunundefined tristanryerparkeundefined 3 Replies Last reply Reply Quote 2
            • CNCModellerundefined
              CNCModeller @dc42
              @dc42 all good progress. Looking forward to getting my hands on one!
              Polar Duet3 Mini + 1HCL
              https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
              Wanhao D4S: Duet2
              https://forum.duet3d.com/post/296755
              K40 Laser, Duet2
              https://forum.duet3d.com/post/312082
              Wanhao D5S
              https://www.youtube.com/CNCModellerUK
              • gregsaunundefined
                gregsaun @dc42
                @dc42 Awesome news, thank you and congrats to Louis as well!
                github.com/gregsaun - Papa Bear
                • tristanryerparkeundefined
                  tristanryerparke @dc42
                  @dc42 Hey David,
                  What kind of current rating are you thinking for these boards?
                  Tristan
                    dc42 administrators @tristanryerparke
                    @tristanryerparke said in closed loop nema 17/23 driver/controller for Duet 3 6hc board:
                    @dc42 Hey David,
                    Tristan
                    Up to 6.3A peak (4.5A RMS) @ up to 50V.
                    We have the new hardware prototypes running now.
                    3DPMicroundefined 1 Reply Last reply Reply Quote 1
                    • 3DPMicroundefined
                      3DPMicro @dc42
                      I am adding cnc capabilities to a manual Lathe at work and was intending to use 2, 4'ish amp Closed loop Nema 23's from Stepperonline and a Duet 2 with expansion board for control. After reading this I would much rather use a MB6HC and the new expansion board. If I could get my hands on one of your new prototypes that would be great. Please let me know if you are interested in dedicating a board for cnc testing. I can be ready in as little as 3 weeks
                      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                        dc42 administrators @3DPMicro
                        @3dpmicro depending on what else you want to drive, it is may be that a Duet 3 Mini + the closed loop boards would be sufficient for your system.
                        3DPMicroundefined 1 Reply Last reply Reply Quote 0
                        • 3DPMicroundefined
                          3DPMicro @dc42
                          Not much else. Spindle control at some point. I can see how the MB6HC would be a bit overkill for the application.
                          • supertb1undefined
                            supertb1 @dc42
                            @dc42 Hello dc42, it is that time of the month and I am as excited as I have been to take part in field testing the new closed loop controller and steppers. How close is Duet3D to coming to market? As always best regards.
                              @supertb1 we'll be starting the beta test phase shortly.
                              martin7404undefined supertb1undefined Luke'sLaboratoryundefined tristanryerparkeundefined CNCModellerundefined 5 Replies Last reply Reply Quote 2
                              • martin7404undefined
                                martin7404 @dc42
                                @dc42 I am interested to test, willing to pay for the hardware
                                Muldex IDEX Duet2+Duex5
                                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                                Sapphire Pro with Duet2, with closed-loop motors
                                custom high temp E3D tool changer with Duet2+Duex
                                • supertb1undefined
                                  supertb1 @dc42
                                  @dc42 I'm with Martin7404
                                  • Luke'sLaboratoryundefined
                                    Luke'sLaboratory @dc42
                                    Sounds neat. What MCU do they use?
                                    I'm definitely in for beta, if you're looking for volunteers. I have machines that are heavily EMF-limited at 325mm/s+, have stepper analyzers, and run 15k accel. I'll make sure they get the hot supper they deserve, and finally max out my Magnum+ with a .4mm nozzle. 🙂
                                    Luke
                                    Luke
                                    http://lukeslab.online
                                    MaxGyverundefined 1 Reply Last reply Reply Quote 0
                                    • MaxGyverundefined
                                      MaxGyver @Luke'sLaboratory
                                      I have a professional IDEX printer prepared for closed loop with Nanotech motors featuring integrated encoders. Since all the cabling is already in place, only the closed loop controllers are missing... I would be very happy to support the beta testing.
                                      -Max
                                        @dc42 I would also like to join the beta crew, and would purchase several once everything is refined.
                                        Thanks
                                          CNCModeller @dc42
                                          Great news! I assume the intern? has had fun getting the code up and running 🙂
                                          I'd be interested in taking part in the beta as well.
                                          Looking forward to seeing how hard I can push the polar printer bed!
                                          Wanhao D4S: Duet2
                                          K40 Laser, Duet2
                                          Wanhao D5S
                                          • Hoops40undefined
                                            Hoops40
                                            I have 7 x 1xd boards for my 5 axis 3d printer build will these new boards work with them?
                                            These are for my 400 watt jmc servos.
