Duet Wifi Closed Loop and Panel Due
Did you take a look at the manual from that github link?
Have you tried connecting the step/direction/enable from the breakout board to the closed loop board yet?
@phaedrux I have, no luck.
@alankilian Which Pin connector should the GND, 5V/3.3V, & Power 12V/24V connect to on the Expansion board?
This post is deleted! -
@gost101 Connect GND and +5 Volts from one of the two Heater connectors.
You'll need to get 12 or 24 Volts from the Duet mainboard.
@alankilian Is there a 12v connector on the board I can use?
@gost101 assuming you're using a 12V PSU, just take it straight from that. The Duet WiFi doesn't have an internal 12V regulator, so if you have a 24V PSU, you can only supply 24v
@alankilian Thats what I thought but wasn't entirely sure. I'll let you know if it works, when I get back home.
I made a quick wiring diagram in paint.
@alankilian @I have 5 closed loop stepper drivers for context. Can I connect all of the closed loops stepper drivers to the same 5V and Ground Terminal or would that break something?
@gost101 That will be fine as long as you don't draw too much current for the 5 Volt supply or the connector you are using.
