    [Revo] New hot end system from E3D?
    63
    4.5k
    • zaptaundefined
      zapta @deckingman
      @deckingman said in New hot end system from E3D?:
      ... the genuine original product would be cheaper and need not be a niche product.
      It depends. If you have government protection for your product, maximizing profit doesn't necessary means maximizing the user base (at a lower per unit cost).
      'innovations' are dime a dozen and if they will chose to be expensive and protected, they will lose the community.
      As for this new product, my understanding that the main selling points are ease of changing nozzles and high flow rate, and if they will be found attractive to the market (I am not sure about that), people will find non infringing ways to provide them.
      This is by no mean a criticism of E3D. They have the right to chose any legal business model they want.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
      • Diamondbackundefined
        Diamondback @zapta
        @zapta RRF does not seem to notice that, it still warns me about a massively high temp (I haven't really tested how high it can go past 290°C, did not want to risk any damage or bake the silicone sock)
        zaptaundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
        • DIY-O-Sphereundefined
          DIY-O-Sphere @zapta
          @zapta
          I wonder if E3D was in any way "inspired" by the maxiwatt heater. It definitely looks very similar...
          (UTC+1)
          • weed2allundefined
            weed2all @achrn
            @achrn no issue tunning on my beta unit!
            https://www.thingiverse.com/weed2all/designs
            achrnundefined 1 Reply Last reply Reply Quote 0
            • zaptaundefined
              zapta @Diamondback
              @diamondback, maybe the curve 'bend' does at a higher temperature.
              PTC elements are used in most hot glue guns, eliminating the need for active control system. As a result, they take much longer than needed to heat because the power reduction starts to take affect very early. Here, they are targeting higher temperatures and have active control system so may have a PTC with a much higher infliction temperature.
              A video by Nero3D also suggests that the Revo hot ends has lower thermal mass which results in faster heating and cooling.
              Diamondbackundefined akstrfnundefined 2 Replies Last reply Reply Quote 0
              • zaptaundefined
                zapta @DIY-O-Sphere
                @diy-o-sphere said in New hot end system from E3D?:
                Looks very similar 😉
                They didn't disclose yet what their patent applications cover. Can be any aspect of the design. I would guess something related to the quick release/change since it may be a good selling point and start a trend.
                EDIT: @diy-o-sphere,m maybe E3D purchase their new heaters from maxiwhatt, who knows.
                • hackinistratorundefined
                  hackinistrator
                  when i first saw the images of it , i thought it is some kind of quick disconnect mechanism to push the nozzle in . Now i realize it the same threaded nozzle , but now its much longer and has an integrated heat break .
                  • oliofundefined
                    oliof @plasticfactory
                    @plasticfactory no, the heater block is held in place by a spring.
                    • o_lampeundefined
                      o_lampe @Diamondback
                      @diamondback @jay_s_uk
                      It would be interesting to see tuning results made with different target temps. That's probably the only way to tell any difference between PTC or linear resistance heaters.
                      My gutt feeling tells me, you can't just tune for PLA-temp and expect same stable result at ABS- or higher temps.
                      • SIamundefined
                        SIam @achrn
                        @achrn said in New hot end system from E3D?:
                        But I expect E3D have some idea that it works...
                        I would say yes, I have no issues with the new hot end it's small it's fast, and it works very fine
                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                        Duet WiFi 1.02 or later + DueX5
                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                        Duet WiFi Server: 1.26
                        Duet Web Control 3.4.0beta4 (2021-09-27)
                          Diamondback @zapta
                          @zapta said in New hot end system from E3D?:
                          In Sanjay's interview with Vector3D, he mentioned that the heater maxes out with a "mild glow" at the very worst case (using a 12V heater with a 36V supply), so yea, very likely that at 300C nothing crazy happens yet. However, you ca see that the avg PWM is higher than "normal" heaters.
                          @o_lampe said in New hot end system from E3D?:
                          I have various stages of this on my TC and they are all tuned for 240°C. I've had no issues with stability with that tuning in the range that I usually print in (210°C to 290°C)
                          The super quick response times usually help PID controls to oscillate at higher frequencies, ie less visible.
                          • achrnundefined
                            achrn @weed2all
                            @weed2all said in New hot end system from E3D?:
                            Thanks. Having now seen more photos (and video) there seems to be a nice large metal-metal face between the top face of the nozzle's enlarged 'head' and the bottom face of the heater (assuming normal downwards-facing-nozzle orientation), which will have the spring keeping it in contact (and stay in contact with differential heating / expansion).
                            Diamondbackundefined 1 Reply Last reply Reply Quote 0
                              Diamondback @achrn
                              That's correct.
                              • zaptaundefined
                                zapta @Diamondback
                                Does the Revo still use groove mount? (vs Slice style screws).
                                • jphillyundefined
                                  jphilly
                                  It would be nice if e3d would get away from using structural heat breaks and groove mount. It does look like there might be a through hole/screw option for deltas just looking at their page. I assume it'll be priced around the mosquito's level but it's worse imo esp. with the non standard nozzles.
                                    Diamondback @jphilly
                                    @jphilly said in New hot end system from E3D?:
                                    Groove mount is only for backwards compatibility. The "real" product uses M12 thread mounting (Revo Micro)
                                    E3D mentioned around 120$ for a full hotend with 4 nozzles.
                                    jphillyundefined 1 Reply Last reply Reply Quote 0
                                    • jphillyundefined
                                      jphilly @Diamondback
                                      @diamondback said in New hot end system from E3D?:
                                      I was quite a bit off then, but I can't see the nozzles or heater being cheap to replace since they're a one off.
                                      I'm not sure about M12 staying put when changing nozzles. At least on my mosquitos it takes a fair bit of torque to loosen a cold nozzle and they're saying it'll be hand loosenable but who knows
                                      Dougal1957undefined Blacksheep99undefined 2 Replies Last reply Reply Quote 0
                                      • Dougal1957undefined
                                        Dougal1957 @jphilly
                                        There has been lots of reports since launch from those that have been beta testing it for the last 10 months or so that are favourable so I don't really think we will have much to worry about as for the screw mount loosening they don't I have been using them since there first inception probably close on 4 years ago.
                                        • akstrfnundefined
                                          akstrfn @zapta
                                          During my testing of PTC heated bed I found out that it is not true that it heats up slower and I tested just a few typed of PTC heaters. The heating curves can be very different from PTC to PTC and I hope E3D produces repeatable PTC heaters. I wanted one for my hotend for a long time.
                                          Semirelater to heater, does anyone know why aren't they putting cables upwards but sideways? So that bend of a cable would happen away from the heater which seems like a no brainer to me...
                                          • achrnundefined
                                            achrn @akstrfn
                                            @akstrfn said in New hot end system from E3D?:
                                            I don't understanmd what you're advocating - if the cable emerged upwards they'd need to immediately bend through 90 degrees with a radius of something like 5mm (maybe less) to clear the heatsink. Emerging as they do, they can be routed with a hundreds of millimetre bend if you want.
                                            Or are you advocatinga cable passage cut through teh heatsink? Wouldn't taht potentially muck up air flows and risk chafing the cables?
                                            https://www.youtube.com/watch?v=OXcZtnzuPuA has some views with the covers off - there's soem decent-looking strain relief built in.
                                            akstrfnundefined 1 Reply Last reply Reply Quote 0
