    Duet3D PCB delta printer effector sneak preview
    53
    367
    77.6k
      See my previous post.
      • a96bimmerm3gmail.comundefined
        Six weeks, sorry. I was a little overzealous!
        • o_lampeundefined
          o_lampe
          Just stumbled across this thread and flipped through the pages without reading every line, so I apologize, if that has been asked before:
          Have you considered putting LEDs on the PCB-bottom?
          • Dougal1957undefined
            Dougal1957
            Have a look at https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer you will see if you scroll down to the underneath pic of it that there is indeed LED's on the bottom surface as well as 2 showing thru the top to indicate Hotend on and Sensor trigger.
            • smunterundefined
              smunter
              I'm in for one once this gets going as well.
              I know adding an IMU was discussed earlier for autolevelling and calibration purposes, but I would another potential use as well: magball disconnect detection. It should be very easy to tell if the effector goes out of level by more than 10 degrees or so, and shut down the printer so no more damage is done. I would take an IMU on board for that purpose alone.
              • Ethelredundefined
                Ethelred
                David, what sort of accuracy/repeatability results are you finding for fully assembled ball-ball spacing across rod pitch and array angularity as well as ball planar relations? Standard PCB hole-hole tolerance is +/- 0.10mm. Add to that slop in the ball stud hole fit, ball-to-stud concentricity ( don't know how Haydn specifies this ) as well as PCB warp and stud flange face to ball center. Serious tolerance budgeting - it might be interesting to see what a three sigma distribution looks like. On the other hand deltas often seem to work fairly well even with some pretty low tolerance angle ball stud (ugh!) printed effector platforms.
                • W3DRKundefined
                  W3DRK
                  Wow…I've just now noticed this topic. What a stunning design, I really love the concept!
                  I was just planning on refitting my delta with wider rod spacing and a piezo Z-probe effector, but I really like this design better than any printable one. For folks with machines like my UltiBots 250 V-Slot...how would we go about mounting the carriage adapters to our existing wheeled carriages like these?
                  https://github.com/UltiBots/K250VS/blob/master/Experimental/umbee_carriage_45.stl
                  Also, if you haven't already is there any chance you could work with the Zesty Nimble crew so they can design a mount for this new heatsink/effector arrangement?
                  Cheers!
                  • A Former User?
                    A Former User
                    @W3DRK:
                    Cheers!
                    Just go buy linear rails and enjoy the precision 😛
                    • W3DRKundefined
                      W3DRK
                      OpenBuilds precision V-Slot and Delrin rollers vs cheap Chinese linear rails? No thanks…
                      @CaLviNx:
                        The carriage adapters have the usual 4 mounting holes on a 20mm square to attach to standard linear rail sliders or Kossel wheeled carriage trucks. If the two holes on one side of that carriage are 20mm apart, then I guess you could drill another hole in the carriage adapter for the single hole on the other side of your carriage.
                        Having first used wheeled carriages and then switched to linear rails, I prefer the rails too.
                        We have a couple of beta users who are investigating how to mount the Nimble on top of the effector.
                        • W3DRKundefined
                          W3DRK
                          Thanks David. Those 3 holes are for the wheels themselves.
                          But it looks like switching to something like this could work if I can find a printable belt fastening mechanism:
                          https://www.thingiverse.com/thing:1638410
                          • SM3Dundefined
                            SM3D
                            Hi David,
                            I have a linear rail carriage with mounting holes on a 26 mm square.
                            Is it possible to have carriage adapters with no mounting holes so I can drill them using a printed jig?
                            Regards,
                            Vasan
                            Good judgement comes from experience but experience comes from bad judgements
                              I think it would be possible (just) to drill 2.9mm holes with 26m centres in the existing carriage adapters. You would have 1.5mm between the inner edges of your new holes and the outer edges of the existing ones.
                              What size linear rails use 26mm mounting centres?
                              • SM3Dundefined
                                SM3D
                                Thanks David for the reply! I might have to be extra careful.
                                I have ARC 15 MN carriage blocks. Here is the link:
                                https://www.dold-mechatronik.de/navi.php?a=45382⟨=eng
                                • SM3Dundefined
                                  SM3D
                                  I forgot to mention that the 26 mm square mounting holes are M4 in size instead of M3. So, I think only undrilled carriage adapter will work for me.
                                  • A Former User?
                                    A Former User
                                    @W3DRK:
                                    @CaLviNx:
                                    Who said anything about buying cheap Chinese ?
                                    I got genuine hinwin rails through work
                                    http://www.hiwin.co.uk/product-category/linear-guideways/hg-series/
                                    • Rommieundefined
                                      Rommie
                                      Any more news on a release date for these. Very interested in one
                                        Looking like early next month.
                                        • Rommieundefined
                                          Rommie
                                          Sweet is there any preorder going on??
                                          • MiRundefined
                                            MiR
                                            Please count me in, now that I am back to Haydn's rods instead of tricklaser rods I am very interested, too….
