PrusaSlicer 2.2 released
New PrusaSlicer 2.2 looks interesting: https://youtu.be/wy3u4DNh_XQ
Might have to finally wean myself off Cura!Ian
@droftarts said in PrusaSlicer 2.2 released:
Already won me some time ago. Prusa seems to put more emphasis on usability.
It works well with duet and even has built in wifi upload and start function.
It's an improvement to be sure, but I find myself missing some of the fine tuning options I get with this Cura build.
https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0&lst=&preview=README.md
Fine control of bridging parameters
Speed and fan control for overhangs
Fine control over speed accel and jerk for all moves
Tree supports
Adjustable fan lag time
Complete control over Z seam placement
Modifier meshes and per part settings have a far more usable GUI
Built in change setting at Z post processor plugin
Duet upload via plugin
Slicing and GUI performance is even greatly improved recently. Almost on par with Prusa Slicer.
Numerous other small tweaks that you simply can do in SlicerThe only pet peeve I have with Cura is that thin wall printing and gap fill is not as good as Slic3r. It's better in that custom build than the regular build, but it still has some issues.
I've slowly switched from Cura to Slic3rPE.
I am sometimes forced to use Simplify3D (long story) and have really come to despise it.
@Phaedrux, not commenting on any specific slicer or controller but I think that in general having that many manual controls is an indication of the immature stage of this technology.
All we need is a single control, to select the color of the printed object.
@zapta said in PrusaSlicer 2.2 released:
I don't think it will ever be as simple as a 2d paper printer. Just look at CNC machining. It's been around for ages and it takes a skilles operator with a specific intention and advanced tools to get good results. And honestly where's the fun in that if it were that easy?
Does anyone know of a slicer which has the concept of tools which aren't necessarily extruders? What I mean by that is the slicer needs only to put a Tn command in the gcode file and can otherwise be completely dumb of what that Tn consists of. I still use a very early version is SliC3r which does that. Slic3R PE assumes that all tools must have a single extruder so before I can use say tool 9 which might be orange (a mix of red and yellow) I have to set up 9 extruders in the slicer, even though only 6 physically exist.
Come to that, does anyone know of a slicer which has no limit (or a very high one) on the number of tools? I need at least 9. -
@Danal said in PrusaSlicer 2.2 released:
Have to agree, I am now trying to use PrusaSlicer primarily. Works really well on the Railcore and the config bundle JohnOFCII produced is superb.
Getting to grips with it for the Ender3 but at least Prusa have included support for it.
S3D, could not justify the cost. ยฃ130 per year.
My twopence worth!P.
@Phaedrux said in PrusaSlicer 2.2 released:
my 2D printer still jams paper...
I've read on e3d forums that Prusa is the only slicer able to handle very high flow extrusions (fast movements and/or big nozzles). Can you guys confirm that?
I first tried PrusaSlicer two days ago, because I needed to test the new object cancellation facility in RRF, which relies on object labelling. I am impressed by it, and planning to switch over to it from S3D. It has other benefits too, such as the built-in file upload to Duets and support for firmware retraction.
@dc42 said in PrusaSlicer 2.2 released:
I was about to ask which slicers support that! Any others?
There was a couple of things in the video I liked the look of. The main thing missing, for me, seems to be tree support, but I donโt use it that frequently in Cura.
Been using prusaslicer/Slic3r PE for years now and has never let me down...
Now that we finally have layer pause option with v2.2 it's sad that it only emitsM601
but RRF only supportM226
for pausing the print.
@dc42 can you implementM601
as an alias forM226
in the firmware? -
@whosrdaddy I donโt think M601 is defined, so you can make a macro in the sys folder called M601.g which will be called when RRF encounters it in Gcode. Then put M226 in that macro. At least, in theory...
@droftarts didn't know about that one.
Printer is busy printing atm but will test this asap, that would be awesome! -
I sliced a 42 MB STL file to a 280 MB gcode file a couple days ago and it ran fine on the printer. I've had trouble in the past with slicing very large STL/gcode files, so they must have fixed something.
@whosrdaddy from the video, I thought you could put any Gcode in at a particular layer? Havenโt watched it again, though.
@matt3o said in PrusaSlicer 2.2 released:
Please post your config.h file.
@whosrdaddy said in PrusaSlicer 2.2 released:
I saw the announcement about this feature. Previous version had an easy to use pause at layer option that worked very well for me.
I just move the vertical layer slider to the layer I want and click on the [+] icon next to the slider. The printer then pauses at that layer, and you can change filament or just resume with same filament.
@droftarts Lol now that you say it, indeed you can. I was too focused on the "pause" thing
@mrehorstdmd they did significant changes to their movement planner. Maybe that helped.
