    Yeyy First print
    229
    • tecno
      tecno last edited by tecno
      So at last the first test print is on its way = so far a happy camper here
      jens55 1 Reply Last reply Reply Quote 1
      • jens55
        jens55 @tecno last edited by
        @tecno, congratultions, now the REAL work starts (tweaking, tweaking and more tweaking) LOL
        tecno 1 Reply Last reply Reply Quote 0
        • tecno
          tecno @jens55 last edited by
          @jens55
          Sorry but it went south 😞
          My Bondtech BMG extruder gave up and started to grind 😞
          jens55 1 Reply Last reply Reply Quote 0
          • jens55
            @tecno, oh well, don't fret, we have all been there. Time to do some tweaking 🙂
            • tecno
              @jens55
              This BMG has been acting badly, now with NO pressure applied filament is not running smoothly.
              Sounds like the gear is wobbling so filament is is type of jerking. Will contact Bondtech tomorrow.
              jay_s_uk 1 Reply Last reply Reply Quote 0
              • jay_s_uk
                jay_s_uk @tecno last edited by
                @tecno that of you don't have the correct thermistor settings in your config so the temperature you think you're at isn't the temperature you have
                Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
                • tecno
                  tecno @jay_s_uk last edited by
                  @jay_s_uk
                  Good morning from a very rainy day 😞
                  Have been trying to find info on this thermistor, maybe I got it with E3DV6 but shure.
                  Cheers
                  Bengt
                  • jay_s_uk
                    @tecno don't think thats an E3D one as they use specific colours for their wires
                    tecno 1 Reply Last reply Reply Quote 1
                    • tecno
                      @jay_s_uk
                      Correct, my bad memory 😉
                      It is HT-NTC100K
                      So do I have to make any changes to my config?
                      • jay_s_uk
                        @tecno what do you have for the M308 line for the hotend?
                        • tecno
                          @jay_s_uk
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                          M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
                          M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
                          M307 H1 B0 R3.567 C155.0 D5.77 S1.00 V24.3 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
                          • PaulHew
                            PaulHew last edited by
                            @tecno You could try changing your B value to 3950
                            From what I have read, that particular type of probe is not very reliable.
                            I tend to use E3D thermistors and at a push TLabs.
                            P.
                            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                            • tecno
                              tecno @PaulHew last edited by
                              @paulhew
                              Hi Paul,
                              I am all ears for good tips.
                              E3D have 3 different Semitec 104GT + PT100 + PT1000
                              Assuming PT100 is a good choice?
                              • droftarts
                                droftarts Moderator @tecno last edited by
                                @tecno PT100 needs a daughterboard. PT1000 is a good choice though. See https://duet3d.dozuki.com/Wiki/Temperature_sensors
                                • tecno
                                  tecno @droftarts last edited by
                                  @droftarts
                                  Hello Ian,
                                  Then PT1000 it is, ordering now from Kent i Denmark.
                                  • droftarts
                                    droftarts Moderator @tecno last edited by droftarts
                                    @tecno To be honest, a proper E3D thermistor, with the correct settings, is fine too. Thermistors are repeatable, not accurate, good resolution. PT1000 are repeatable, accurate, slightly lower resolution. Either way you'll need to work out the reported temperature that works for you filament (speed is also a factor), and even your current HT-NTC100K should be fine. Try printing a temperature tower. Something like https://www.thingiverse.com/thing:2729076
                                    • tecno
                                      Managed to make my first print yesterday evening by replacing nozzle to brass on Dragon. The suppied nozzle is not OK.
                                      Good tool to have.
                                      tecno 1 Reply Last reply Reply Quote 2
                                      • tecno
                                        tecno @tecno last edited by
                                        On purpose !!!!
                                        Just to play a little hardboll no G29 S1 = Print went south west as suspected 😉
                                        The picture in message is acceptable with loaded heightmap
                                        • tecno
                                          Last parts printed for the mechanical upgrade on my Chiron, Y axis linear guides.
