    Duet 3 3HC CAD Model Request
    17
    1.2k
      jay_s_uk
      Any chance of getting a 3D CAD model of the duet 3 3HC board?
      • blt3dpundefined
        blt3dp
        It's on the Wiki
        https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_3D_Model
        My 3D Printing YouTube Channel
        Better Living Through 3D Printing
        Follow me on Instagram and Twitter
        Instagram
        Twitter
          jay_s_uk @blt3dp
          @blt3dp
          3HC, not 6HC
          blt3dpundefined 1 Reply Last reply Reply Quote 0
          • blt3dpundefined
            blt3dp @jay_s_uk
            @jay_s_uk
            Oops, totally mixed that up.
            Instagram
            Twitter
              jay_s_uk @blt3dp
              @blt3dp don't worry
              • kroybalundefined
                kroybal
                Also interested in CAD model, any luck?
                Nuramoriundefined 1 Reply Last reply Reply Quote 0
                • Nuramoriundefined
                  Nuramori @kroybal
                  This post is deleted!
                    T3P3Tony administrators
                    I have added a link on the documentation page to the file hosted on github:
                    https://duet3d.dozuki.com/Wiki/Duet_3_Expansion_Hardware_Overview#Section_3D_Model
                    Phil Maddoxundefined 1 Reply Last reply Reply Quote 2
                    • Phil Maddoxundefined
                      Phil Maddox @T3P3Tony
                      @T3P3Tony Sorry but the file wont open/ import in either F360 or Autodesk Inventor (2016)
                      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                      • DIY-O-Sphereundefined
                        DIY-O-Sphere @Phil Maddox
                        @Phil-Maddox
                        Right click "View raw"
                        Then perform" Save as"
                        It's a little bit tricky to download a single file on Github.....
                        (UTC+1)
                        Dizzwoldundefined 1 Reply Last reply Reply Quote 0
                        • Dizzwoldundefined
                          Dizzwold @DIY-O-Sphere
                          @DIY-O-Sphere
                          Any ideas on have to download it on a mac?
                          • infiniteloopundefined
                            infiniteloop @Dizzwold
                            @Dizzwold
                            As described above. Use the link provided by @T3P3Tony, follow the link "3HC STEP File on github", there, use the context menu with a right click as @DIY-O-Sphere illustrates with his screenshot. You then might be asked whether you want to permit downloads from GitHub. You then will find the file "Duet3_Exp_3HC.step.txt" in your "Downloads" folder where you need to remove the second extension (".txt") from the file name. Finally, you need an app which can handle the .step file …
                            • Dizzwoldundefined
                              Dizzwold @infiniteloop
                              @infiniteloop
                              Thank you for confirming what I'd already tried.
                              It would seem my problem lies with Fusion from the following;
                                @Dizzwold said in Duet 3 3HC CAD Model Request:
                                Well, in the meantime, I tried further: removing the .txt file type seemed to work in Finder, but the extension reappeared after editing. Use the file info dialog for that.
                                I don't use Fusion but FreeCad - after I had really renamed the file, I could import it without problems:
                                • Dizzwoldundefined
                                  @infiniteloop
                                  The 6hc link comes up with 404 missing.
                                  https://github.com/Duet3D/Duet3-Mainboard-6HC/tree/master/Duet3_Mainboard_v1.0
                                  Are there any new links?
                                    Phaedrux Moderator @Dizzwold
                                    @Dizzwold https://github.com/Duet3D/Duet3-Mainboard-6HC/tree/master/Duet3_Mainboard_6HC_v1.0
                                    URL just changed to add 6HC
                                    Dizzwoldundefined 1 Reply Last reply Reply Quote 1
                                    • Dizzwoldundefined
                                      Dizzwold @Phaedrux
                                      @Phaedrux @infiniteloop @DIY-O-Sphere
                                      Thank you guys, Got it now.
                                      • dc42undefined dc42 marked this topic as a question
                                      • dc42undefined dc42 has marked this topic as solved
