    Issues with pressure advance since RRF 3.4
    308
    37.9k
    • jens55undefined
      jens55 @gloomyandy
      @gloomyandy, I do not use input shaping. It's been likely a year or more since I last ran these tests. I can not reasonably claim that nothing else has changed. Heck, I wouldn't even know where to start the recreating of old config.g files. I am not in a position to start reverting to old versions. I have neither the time nor the energy to go through that process in a thorough manner. I will likely continue my experimenting for a while but it isn't an exhaustive investigation (and is not meant as such). I am simply throwing my observations into the mix of things.
      gloomyandyundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @jens55
        @jens55 If you are not using any 3.4 features, I don't think switching to 3.3 would be a big problem, your 3.4 configuration should work I think.
          jay_s_uk @jens55
          @jens55 i've ran a 3.4 config with 3.2 quite happily
          Argoundefined 1 Reply Last reply Reply Quote 0
          • Argoundefined
            Argo @jay_s_uk
            @jay_s_uk
            Did you already have the time to print a comparison between RRF and Klipper on your setup?
            • Adrian52undefined
              Adrian52 @jens55
              @jens55 I was stimulated by your post to try again a gcode script I use to calibrate PA, adapted from a previous post. For me, this seems to work as expected:
              It does 4 lines at 20mm/sec, then 4 lines speeding up from 20mm/sec to 100mm/sec and back for each PA setting - I have pictured to speeding up section, where you can clearly see the effect of PA, and confirming the .04 I usually use.
              My system is pretty basic - duet2wifi with no SBC running 3.4.4, with mzv IS, single nozzle, direct drive orbiter 2.
              Adrian52undefined 1 Reply Last reply Reply Quote 0
              • Adrian52undefined
                Adrian52 @Adrian52
                @Adrian52 should add that the script is adapted from that posted by DonStauffer (https://forum.duet3d.com/user/donstauffer) here
                https://forum.duet3d.com/post/250961
                I found it quicker without a raft, so made an anchor piece to start the test strips . Apologies to DonStauffer for mangling your script.
                ;	set variables
                var StartX = -70
                var StartY = -25
                var LinesPerTest = 4
                var LinesBetweenTests = 4
                var AnchorLines = 10
                var TempBed = 60
                var TempTool = 195
                var ToolNum = 0
                var Ext1 = 0
                var Ext2 = 1
                var Width = 0.55
                var Height = 0.2
                var ExFactor = 1.0
                var Retract = 1.0
                var Prime = 0	;	Before Raft
                var PALow = 0.0
                var PAHigh = 0.07
                var PAIncrement = 0.01
                var SpeedRaft = 400
                var SpeedSlow = 1200
                var SpeedFast = 6000
                var SpeedTravelXY = 9000
                var SpeedTravelZ = 1200
                var SpeedRetract = 7200
                ;	Calculated and Utility Variables
                var TestCount = 1 + floor((var.PAHigh - var.PALow) / var.PAIncrement + 0.5)
                var FilFactor = var.ExFactor * var.Width * var.Height / (pi * 1.75 * 1.75 / 4)
                var PA = var.PALow - var.PAIncrement
                var Dist = 0
                ;	PREPARE
                T{var.ToolNum}
                M82	;	Extruder Absolute Mode
                ;	Heat Bed and set Hot Ends to Standby
                M400
                M117 "Heat"
                M140 S{var.TempBed}				;	set Bed Temp
                M568 P{var.ToolNum} S{var.TempTool} A2	;	set Tool Temp
                M116 H{var.ToolNum + 1} S1			;	Wait for temp
                G4 S12					;	Delay to Allow for Overshoot
                M116 H{var.ToolNum + 1} S1		;	Wait for Recovery
                M116 H0 S1					;	Wait for Bed
                M400
                M117 "Home"
                G1 Z30 F3000
                G30
                M400
                ;M117 "Anchor"
                ;	Go to StartX - Width *5, StartY
                G90	;	Absolute
                G92 E0
                G0 E{-var.Retract} F{var.SpeedRetract}
                G1 X{var.StartX - var.Width * (var.AnchorLines-4) } Y{var.StartY} F{var.SpeedTravelXY}
                G1 Z{var.Height} F{var.SpeedTravelZ}
                G91	;	Relative
                set var.Dist = (2 * var.TestCount * var.LinesPerTest + var.LinesBetweenTests * (var.TestCount - 1)) * var.Width
                M221 S110 ;set extrusion factor to 110% for anchor
                while iterations < var.AnchorLines
                	;	Draw anchor Line
                	G0 Y{var.Dist} E{abs(var.Dist) * var.FilFactor} F{var.SpeedRaft}
                	G92 E0
                	;	Break here if last time
                	if iterations + 1 >= var.AnchorLines
                		break
                	;	Move Over
                	G0 X{var.Width} E{var.Width * var.FilFactor} F{var.SpeedRaft}
                	G92 E0
                	set var.Dist = -var.Dist
                G0 E{-var.Retract} F{var.SpeedRetract}	;	Retract
                ;	BEGIN TEST PATTERN
                M400
                M117 "Test Pattern"
                ;	Go to StartX, StartY
                G90	;	Absolute
                G1 X{var.StartX} Y{var.StartY} F{var.SpeedTravelXY}
                G91	;	Relative
                while iterations < var.TestCount
                	;	set PA
                	set var.PA = var.PA + var.PAIncrement
                	M572 D{var.Ext1} S{var.PA}
                	M572 D{var.Ext2} S{var.PA}
                	echo "PA=",{var.PA}
                	;	Draw Reference Lines
                	while iterations < var.LinesPerTest
                		G0 E0 F{var.SpeedRetract}		;	Unretract
                		G0 X140 F{var.SpeedSlow} E{140 * var.FilFactor}
                		G92 E0
                		G1 Y{var.Width} F{var.SpeedTravelXY}
                		G1 X-140 F{var.SpeedTravelXY}
                	;	Draw Test Lines
                		G0 X35 F{var.SpeedSlow} E{35 * var.FilFactor}
                		G0 X70 F{var.SpeedFast} E{105 * var.FilFactor}
                		G0 X35 F{var.SpeedSlow} E{140 * var.FilFactor}
                		G92 E0
                	;	Move to start of next comparison
                	G1 Y{var.LinesBetweenTests * var.Width} F{var.SpeedTravelXY}
                ;	Finish up
                M400
                M117 "Done"
                G10 P0 S0 ; turn off temperature
                M140 S0  ;turn off bed heater
                G28  ; home
                  jay_s_uk @Argo
                  @Argo I have but I'm awaiting some feedback for I post anything
                  • jens55undefined
                    jens55 @Adrian52
                    @Adrian52, thanks for posting the script and the results. I will see if I can get that working here!
                    • jens55undefined
                      jens55
                      I went back to the original script posted by DonStauffer with the raft and I did see the ever so subtle change in the printout. Interpretation of the test print is difficult but it works better than what my previous script was able to do.
                      I kept the raft so I could remove the finished print in one piece and examine it clearly. I did have adhesion problems because it's a single line and I am working on adjusting my bed temperature to fix that.
                      Final verdict: I didn't know what I was doing and pressure advance does in fact work on the CR10 printer. I have not yet tried this on the Jubilee where the extruder is driven off a tool board. Note that this only speaks to PA changing and not necessarily to how effective the PA is in an actual print.
                      Tests are ongoing ......
                      • gnydickundefined
                        gnydick
                        This post is deleted!
                        • Heartleander81undefined
                          Heartleander81
                          Update on my conversion to Klipper.
                          At first the corners didn't look any better than with RRF until I came across a post today that refers to extruder smooth time.
                          The standard is with Klipper 0.04, which I also use.
                          Switched to 0.01 and the corners look awesome.
                          In the article it was said that some extruders can not cope with the smooth time and then you have to get smaller. see my pictures.
                          With smooth time 0.04
                          With smooth time 0.01
                          R4ffersundefined Argoundefined 2 Replies Last reply Reply Quote 2
                          • R4ffersundefined
                            R4ffers @Heartleander81
                            @Heartleander81 wow mate what a difference
                            Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
                            Heartleander81undefined 1 Reply Last reply Reply Quote 0
                              Heartleander81 @R4ffers
                              @R4ffers oh yes.
                              @dc42 is there also something like pressure advance smooth time under RRF? A few clippers have the problem with the high smooth time, but those who have problems are mostly DirectDrive extruder users. Maybe that's an approach you can follow.
                              Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @Heartleander81
                                @Heartleander81 Can you link that article you mention?
                                sebkritikelundefined 1 Reply Last reply Reply Quote 0
                                • sebkritikelundefined
                                  sebkritikel @Phaedrux
                                  @Phaedrux I see some discussions on it at the bottom of Klipper's Kinematics page
                                  https://www.klipper3d.org/Kinematics.html
                                  Some other pages of interest
                                  https://klipper.discourse.group/t/pressure-advance-smooth-time-on-direct-extruders-with-short-filament-path/1971
                                  https://github.com/Klipper3d/klipper/issues/4442
                                  richfelker created this issue in Klipper3d/klipper
                                  closed Pressure advance smoothing induces e-axis position swings that scale with acceleration #4442
                                  Large(ish?) IDEX - 6HC, 1HCL
                                  Stratasys Dimension 1200es to 6HC Conversion
                                    dc42 administrators @Heartleander81
                                    @Heartleander81 said in Issues with pressure advance since RRF 3.4:
                                    @R4ffers oh yes.
                                    No, there isn't anything similar. I will look into that Klipper feature.
                                    The reason I have made no progress on this is that while a number of users seem to think that pressure advance doesn't work as well in RRF 3.4 as it did in 3.3, and I am prepared to believe that there may be a difference because the relevant code had to be rewritten to accommodate input shaping, nobody has been able to provide a simple GCode script and machine settings that demonstrate a difference when input shaping is disabled. That includes me - I have compared RRF 3.3 and RRF 3.4 prints.
                                    Heartleander81undefined petriheinoundefined CR3Dundefined gnydickundefined camnewnhamundefined 5 Replies Last reply Reply Quote 0
                                      Heartleander81 @dc42
                                      @Phaedrux
                                      I couldn't find any differences between 3.3 and 3.4.x, but I still have a picture of a test where the corners became nice with PA. As now with klipper. The Artikel from sebkritel is that who I read.
                                      • Argoundefined
                                        Argo @Heartleander81
                                        @Heartleander81
                                        So altering the smooth time value did improve your corners and PA alone did not?
                                        • petriheinoundefined
                                          petriheino @dc42
                                          Hi folks, my guess is OP simply did finer calibrations after update and found out underlying RRF issues regarding PA, Retraction, Extruder steps and acceleration relation... I got similar results (improvements) with Klipper conversion. I did some testing and posted it here earlier.
                                            Heartleander81 @Argo
                                            @Argo said in Issues with pressure advance since RRF 3.4:
                                            PA alone didn't make the whole corner look nice. See the picture with the corner sticking out in the direction of travel. Only with the change of smooth time and renewed PA, which was then higher, did the corners become so clean.
                                            Argoundefined 1 Reply Last reply Reply Quote 1
