Duet3D announces new tool board at FormNext
107
9.2k
    Surgikill @Surgikill
    Eh, I just found some basic documentation and max ambient printing temp is 40C. Think I'm going to have to pass on this extruder.
    undefined 1 Reply Last reply 25 Nov 2023, 09:08 Reply Quote 0
      o_lampe @Surgikill
      @Surgikill said in Duet3D announces new tool board at FormNext:
      Can you quote this or add a link for us?
      I wonder if that's related to the 3d printed heatsink? Maybe it's thermal conductivity is too low.
      Funny enough they dont conduct heat from the stepper, but added a thermal barrier between.
      undefined undefined 2 Replies Last reply 25 Nov 2023, 09:14 Reply Quote 0
        jay_s_uk @o_lampe
        @o_lampe must be this bit he's quoting
        https://beta.e3d-online.com/pages/help-centre-roto#:~:text=Performance Characteristics,temperature%3A 40°C
        undefined 1 Reply Last reply 25 Nov 2023, 12:16 Reply Quote 1
          o_lampe @o_lampe
          I've checked some papers and the conductivity of SLM printed aluminum-alloy is in the ballpark of conventional aluminum alloy material
          Pure aluminium: 237 W/mK
          SLM printed AlSi10Mg: 130-190 W/mK
          Other Aluminium alloys vary from ~90-150 W/mK
          So, if it's not the SLM-heatsink it must be poor design choices regarding airflow?
          undefined 2 Replies Last reply 25 Nov 2023, 10:28 Reply Quote -1
            gloomyandy @o_lampe
            @o_lampe The max service operating temperature (not 100% sure what that means) for the motor is listed as only 50C so perhaps the max overall ambient temperature is related to that?
              gloomyandy @o_lampe
              @o_lampe I guess the best thing to do is to ask e3d what the basis is for that 40C limit.
                Surgikill @jay_s_uk
                @jay_s_uk yes, that is where I got the info. I know in the interview they said this heatssink is the most efficienct they have ever designed, going as far to say they printed pla at 40c ambient temp. I'm not sure if this is why it's rated at 40c, or if it's the plastic planetary gears.
                undefined 1 Reply Last reply 25 Nov 2023, 17:46 Reply Quote 0
                  elmoret @Surgikill
                  Based on how E3D rates things, 40C is the “PLA without jamming” temperature
                  undefined 1 Reply Last reply 25 Nov 2023, 18:51 Reply Quote 0
                    Surgikill @elmoret
                    @elmoret if that's the case then it's a different story, but if the motor is only rated to 50c then I don't see it going over that, which is still pretty low.
                      gnydick @edsped
                      @edsped I've found even for one tool head, I'd trade the cost for the convenience of not having to run 19 conductors for each tool.
                      • heater: 2
                      • thermistor: 2
                      • fan: 3
                      • fan: 4
                      • stepper: 4
                      • filament sensor/(un)load trigger button: 4
                        Surgikill
                        Anybody have any idea why the motor on the roto is only rated for 50C? Looking at the 36mm LDO pancake stepper, it is rated at 180C. Not sure how accurate that is, but it is a gulf between the roto and the LDO, and they look like the same motor.
                        undefined 1 Reply Last reply 27 Nov 2023, 12:11 Reply Quote 0
                          sebkritikel @Surgikill
                          @Surgikill Most stepper motors used by 3D printing enthusiasts are built using 'Class B' insulation for the motor windings. For 'Class B', the max allowable winding insulation temperature is 130°C, which often yields a max motor ambient temperature of 40-50°C (not stepper casement temperature).
                          http://www.drivesandautomation.co.uk/useful-information/nema-insulation-classes/
                          Example motor with specs on insulation, thermal rise, etc
                          https://catalog.orientalmotor.com/item/2-phase-bipolar-stepper-motors/42mm-pkp-series-2-phase-bipolar-stepper-motors/pkp244d08a2
                          Most of us skirt by this 'max temperature' limitation by running steppers at 85% or so of the rated current, that gives some margin for an elevated ambient temperature. Running with an ambient temperature higher than the spec'd motor ambient could result in reduce service life for the motor. Ends up most of us ignore what 'Class B' insulation means, or simply don't know (I have been ignoring it, been running ambients in the 60-70°C on my motors 🤠 )
                          Without looking at a datasheet... the roto motor likely has 'Class B' insulation.
                          Speaking of datasheets, a lot of steppers used in printers seen here don't go into the detail manufacturer's like Oriental Motor use on their datasheets (example snippet from a popular stepper seen here):
                          If you read the specs above, and don't further research what 'Class B' means, you might assume the motor running at 130°C is fine... and by running at 130°C, one might think thats the easily observable casement temperature (they do get hot!).
                          With extruder motors, its often recommended to run them at a significantly reduced current (at least when they were using smaller NEMA17 motors) for two reasons:
                          1. The torque at full current was much greater than what was needed for extrusion force
                          2. The casement thermal rise at full (or 85%) current could soften the filament, depending on how the filament drive was connected to the stepper)
                          Its possible that, while the roto motor uses 'Class B' insulation, it doesn't need to run at rated current, meaning theres higher margin for ambient temperature (maybe, a good amount of conjecture on my part of the requirements of the roto motor 🙂 )
                          As far as that LDO pancake stepper, LDO has been making a series of high temperature motors for the enthusiast community using higher rated winding insulation.
                          Large(ish?) IDEX - 6HC, 1HCL
                          Stratasys Dimension 1200es to 6HC Conversion
                          undefined 1 Reply Last reply 27 Nov 2023, 14:02 Reply Quote 3
                            Surgikill @sebkritikel
                            @sebkritikel Awesome, thanks for the info. The LDO pancake does use class H insulation from the datasheet. What I am wondering is if the E3D motor could be replaced with the LDO to raise the ambient operating temp of the system to >40C. The Roto motor seems to be different from the LDO (Max current of 0.6A vs 1.0). It appears the spur gear on the stepper may be different.
                            undefined 1 Reply Last reply 1 Dec 2023, 02:30 Reply Quote 0
                              curieos
                              @dc42 Is the Roto toolboard going to be compatible with the existing tool distribution board? Will there be an updated distro board with the new connector? Is there the possibility for an updated 1LC with the new connector?
                              She/Her
                              I work at a local 3D printing shop.
                              Printers: Micron+ w/Duet 3 Mini, in-progress adaptation of the Jubilee REL onto an E3D MS, Prusa i3 MK3S.
                              undefined 1 Reply Last reply 30 Nov 2023, 19:20 Reply Quote 0
                                dc42 administrators @curieos
                                @curieos you can use the Roto tool board with the existing tool distribution board (TDB) like this:
                                If the cable length from the TDB to the TOOL1RR is no more than 1m:
                                • Connect the Roto CAN wires to just two of the pins on the 4-pin connector on the TDB
                                • Install the bypass jumpers for that port on the TDB
                                If it's more than 1m:
                                • Don't install the bypass jumpers for that port on the TDB
                                • Run 2 twisted pairs from the 4-pin connector on the TDB to a junction point no more than 1m from the TOOL1RR, then use the TOOL1RR cable to connect the ROOL1RR to that junction.
                                In time we are likely to produce a new TDB with more connection options.
                                  elmoret @Surgikill
                                  @Surgikill the trouble with letting the motor get hotter is that it will result in the gearbox temperatures being exceeded - not a simple change to make, or I’m sure they’d have done it. 180C windings are also more expensive, and of no benefit to 95% of users.
                                  Maybe a HT version in the future, with 180C windings and an uprated gearbox… but then the fan’s the limit. So water cooling? And round and round you go, building a product for an increasingly small customer set.
                                  undefined 1 Reply Last reply 1 Dec 2023, 06:58 Reply Quote 0
                                    deckingman @elmoret
                                    @elmoret said in Duet3D announces new tool board at FormNext:
                                    And as you said above, the temperature limit could be based on printing PLA without jamming. That might be down to the efficiency of the heat break. If so, then when you get up to circa 80 Deg ambient, other filaments might start to jam too. From what I've been told, most electronic components will have a shorter life when subjected to higher temperatures so it may be the case that users might have accept a much shorter service life and replace the boards every year or so. All in all, it might just be better to enclose the print head from the heat break upwards in some sort of box and pump cool ambient air into it. A bit of a pain to do but it might work out cheaper in the long run.
                                    undefined 1 Reply Last reply 2 Dec 2023, 17:47 Reply Quote 0
                                      Surgikill @deckingman
                                      @deckingman from the video interview they did they said that this heatsink is the most efficient heatsink they have ever designed, but that doesn't mean it can wick away more heat.
                                      I'm hoping that the limit is pla printing, but I kind of doubt it. I might be able to get away with 40c chamber temp, but would much rather run at 65. Guess I will just have to use the hemera xs.
                                      undefined 1 Reply Last reply 2 Dec 2023, 19:20 Reply Quote 0
                                        jay_s_uk @Surgikill
                                        @Surgikill I spoke to E3D about this today. The limitation on the 40 degrees is the motor, nothing else. They will releasing a more capable motor in the new year
                                        undefined 2 Replies Last reply 4 Dec 2023, 16:07 Reply Quote 4
                                          Surgikill @jay_s_uk
                                          @jay_s_uk Awesome. Thanks for the heads up. I submitted a support request but haven't heard anything back.
                                          66 out of 107
