    CNC Category
    CNC
    • T3P3Tony
      Would it be helpful to split out CNC specific queries to their own category?
      Tagging @Catalin_RO @keyz182 @Danal @timcurtis67 @Russ-Gries @Ryan-Lock @hpiz @Jacotheron @CVMichael @OwenD @mawildoer as you guys have posted on CNC topics. Feel free to tag in others.
      Duet Hardware Designer
      www.duet3d.com
      Catalin_RO 1 Reply Last reply Reply Quote 0
      • keyz182
        keyz182 last edited by
        I don't think it'd hurt, and with the way it looks like Duet 3 is going, it could see a bigger share of CNC coming this way.
        For me personally though, it won't really affect me, I just browse the forum under "All Categories". Though potentially as things grow bigger, that may change.
        • Catalin_RO
          Catalin_RO @T3P3Tony last edited by
          @t3p3tony I think it would help! Just think of a newcomer trying to go through the existing discussions when most of them are FDM specific. Having separate categories for CNC and laser cutting would help a lot, maybe even reducing the amount of required support.
          • Jacotheron
            Jacotheron last edited by
            I agree with @Catalin_RO - it will help sort topics for the newcomers.
            • timcurtis67
              timcurtis67 last edited by
              I think it will be easier for new comers to the firmware.
              Duet 3 will draw more CNC's with it's new flexibility for sure.
              • T3P3Tony
                CNC category has been created. I have moved this topic in. If there are any key topics/discussions on Duet &CNC feel free to suggest them and i will move them into here as well.
                www.duet3d.com
                • Catalin_RO
                  @t3p3tony I did a quick search on the forum and found these threads that might be worth moving here:
                  • https://forum.duet3d.com/topic/4669/ooznest-workbee-screw-driven
                  • https://forum.duet3d.com/topic/7364/multi-spindle-cnc
                  • https://forum.duet3d.com/topic/4313/cnc-workplace-coordinates
                  • https://forum.duet3d.com/topic/9269/yet-another-cnc-improvement-outside-machine-limits
                  • https://forum.duet3d.com/topic/4680/increase-work-coordinates-precision
                  • https://forum.duet3d.com/topic/10234/4th-axis-post-processor
                  • https://forum.duet3d.com/topic/8826/strange-issue-when-running-programme-on-cnc
                  • https://forum.duet3d.com/topic/8116/setting-wcs-with-probe
                  • https://forum.duet3d.com/topic/5503/dual-y-axis-and-rotary-a-axis
                  • https://forum.duet3d.com/topic/4557/cnc-coordinate-systems
                  • https://forum.duet3d.com/topic/10292/duet-wifi-for-cnc-work-coordinates-and-mesh-bed-leveling-issue
                  • https://forum.duet3d.com/topic/8955/general-questions-about-using-duet-for-traditional-cnc
                  • https://forum.duet3d.com/topic/5654/problem-controlling-a-cnc-spindle
                  • https://forum.duet3d.com/topic/8796/duet3d-controlling-relay-spindle
                  • https://forum.duet3d.com/topic/7543/vesc-spindle-control-for-cnc-mill
                  • https://forum.duet3d.com/topic/4762/vfd-spindle-drive-0-10v-output
                  • https://forum.duet3d.com/topic/8653/software-to-use-3d-printer-as-an-engraver-spindle-motor
                  • https://forum.duet3d.com/topic/9693/duet-2-controlling-a-cnc-spindle-vfd-via-pwm
                  • https://forum.duet3d.com/topic/9156/cnc-firmware-for-the-paneldue
                  • https://forum.duet3d.com/topic/1662/running-gcode-cnc-on-duet-wifi
                  • https://forum.duet3d.com/topic/17/milling-cnc-with-duetwifi
                  • https://forum.duet3d.com/topic/6454/duetwifi-on-a-wood-alu-router
                  • https://forum.duet3d.com/topic/7339/issues-with-m585-for-cnc-milling
