Parts are coming out too small...
Am i supposed to enable relative extrusion distances in the slicer ? And where do i start to deal with the issue of parts coming out smaller than they are supposed to. I can get them to print well but not dimensionally accurate...
Can you spend a little time giving us some information about your printer?
What kind is it?
Did you build it yourself?
Did it ever work properly?What kind of Duet board do you have?
What version of firmware are you using?
Can you post your config.g config-overrides.g files so we can see how it's configures?Can you post the STL for a file you're having problems with?
Can you post a photograph with measurements for the part you're having problems with?
That will let people here get you some help.
I would first start with making sure your steps/mm are correct in the firmware. One thing you can do if you think you do have them set correctly is to fine tune them with this formula:
A = current steps per mm
B = Actual steps movedA(100/B)
I will use the X axis as an example.
- Set your starting position in a spot where you can easily measure between two points on the X axis, if you have calipers even better and 0 out the starting distance.
- Tell the printer to move the X axis 100mm and then measure the distance that it actually moved, this will be the "B" number of the formula below. This will give you a new steps/mm that you enter in the firmware.
Repeat the steps for Y axis and Z axis and even your extruder. For the extruder just make a mark on your filament at 110mm above where it enters the extruder once it has finished extruding measure the distance to the mark. Take that measurement and subtract 10, if it is positive you are not extruding enough, negative, extruding to much, zero you are right on.
@dakingofhearts2003 when you say smaller how much are we talking? .1mm or 1mm?
@alankilian @alankilian I have the duet wifi and it is a qidi tech 1 which is a flashforge clone. I am using the lastest version of the firmware it always has printed since i configured it but the parts are inaccurate since i changed boards.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Jul 25 2020 12:56:48 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"Qidi nova" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; disable Telnet; Drives
M564 H0 ; allow not homed axis movement
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M350 X32 Y32 Z32 E32 I1 ; configure microstepping with interpolation
M92 X160.00 Y160.00 Z800.00 E909.59 ; set steps per mm
M566 X800.00 Y800.00 Z20.00 E400.00 ; set maximum instantaneous speed changes (mm/min)
M203 X40000.00 Y40000.00 Z200.00 E2200.00 ; set maximum speeds (mm/min)
M201 X4500.00 Y4500.00 Z200.00 E1000.00 ; set accelerations (mm/s^2)
M906 X800 Y700 Z500 E950 I15 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; pressure advance ;set pressure advance for direct drive nova hotend
M572 D0 S0.04; Axis Limits
M208 X225 Y145 Z165 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Z0 ; configure Z-probe endstop for low end on Z
M558 P9 H5 F500 T4000 X0 Y0 Z1 :set probe type and mode. not using on xy but using it on z axis; Z-Probe
M558 P9 C"^zprobe.in" H5 F6000 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P50 X-49.41 Y8.53 Z4.207 ; set Z probe trigger value, offset and trigger height
M557 X10:205 Y10:145 S10 ; define mesh grid; autosave 911
M911 S21.0 R23.0 P"M913 X0 Y0MG91 M83 G1 Z3 E-5 F1000; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S1 H0:2 ; set fan 1 value. Thermostatic control is turned on
M106 P1 S1 H0:1 T45 ; set fan 1 value. Thermostatic control is turned on
M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
M106 P2 S1 H0:1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P0 S"Extruder" D0 H1 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CM501
M500
M564 H0
; Custom settings are not defined -
@3dpmicro
one comes out the right size on my tevo but the duet board died and before that would always disconnect so im about to throw one of my old boards with marlin on it in it. I'd like to get this one right first though...
@dakingofhearts2003 said in Parts are coming out too small...:
M92 X160.00 Y160.00 Z800.00 E909.59 ; set steps per mmHow did you calculate the X and Y steps per mm? Is your Z steps per mm correct?
Taking a stab, but 20mm/24.2mm=83%. 160steps/mm / 200steps/mm=80%.
Are you sure you've properly calculated the X and Y steps per mm? I think its likely you have 16 teeth pulleys instead of 20 teeth (or an equivalent mistake).
@sebkritikel i tried the old numbers from the makerbot and used the 80 80 400 standard of marlin. the old makerbot numbers just made it print off the bed and etc. the marlin standard made the parts come out undersized
Thanks for the update!
Take a look at those formulas I posted - it’s fairy straight forward. Looks like your motors are 1.8deg motors, so 200 steps/rev (360/1.8). Per your M350, you have 32x micro stepping. Your belt pitch is likely 2mm.
In your case the ‘80 80 400’ “standard” doesn’t work as you have 32x microsteping. Had you selected 16x, bam, the ‘80 80 400’ would likely have worked.
However, those numbers aren’t working for you, and ~20% is fairly significant to be attributed to the extruder. The last variable in the equation is the pulley size/setup... double check that.
Plugging numbers into config.g willy nilly can get you far, but it’s always good to fall back on documented formulas to work out issues like this.
@sebkritikel when i did the extruder calibration it was correct. I did make a start mark on the bed and did a 50mm in the x direction and i measured 42.17. I didnt know i was going to need to be an engineer to change boards and firmware i see why people buy prusas now cause im sick of tinkering and wasting filament...
@dakingofhearts2003 well let me know if you need more help. Bummed to hear I didn’t get you pointed in the right direction.
@sebkritikel i think im going back i'm just tired of it...
I didnt know i was going to need to be an engineer to change boards and firmware i see why people buy prusasI can partly understand your frustration, as RRF and Duet boards are getting more and more sophisticated
They offer more options, but also ask more from the user. Like reading manuals and listen to experienced users....
