    Duet Wifi Closed Loop and Panel Due
    Accessories and Add-ons
    breakout board closed loop help panel due setup wiring
    1.5k
    • Gost101undefined
      Gost101
      Good Day everyone,
      I am once again asking for your help.
      I bought 5 of these closed loop drivers for the breakout board and do not want to screw up the wiring. Hd987706388d44bf4bc9b43029b27291a5.jpg_640x640q90.jpg
      In addition, I have a 7" panel due that is connected over the ribbon cable as the guide suggests and I have added the ```
      M575 P1 S1 B57600
      ![20210813_180512.jpg](/assets/uploads/files/1628902118736-20210813_180512.jpg)
      Here is a print out from the YAT terminal: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.3beta1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2021-02-14 16:00:49<LF>ok<LF>
      What should I do?
      • Gost101undefined
        Gost101
          Update your firmware to 3.3 final for the duet and the panel.
          Make sure the panel baud rate in the setup page matches the value in config.g
          Have you tried the 4 wire connection method yet?
          Gost101undefined 1 Reply Last reply Reply Quote 0
          • Gost101undefined
            Gost101 @Phaedrux
            @phaedrux The Panel Due now works. Thanks. But how should I wire the stepper motor drivers from the breakout board?
              Have you seen this page?
              https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
              Do you have any information on how that board uses the step/direction/enable pins? I'm not familiar with that board myself.
              • Gost101undefined
                Gost101
                @phaedrux I have seen that post and no I am not familiar with the wiring of the closed loop driver that's why I asked LOL. Do you know anyone who might be?
                  Do you have a link for the big tree tech board?
                  JoergS5undefined 1 Reply Last reply Reply Quote 0
                  • JoergS5undefined
                    JoergS5 @Phaedrux
                    @phaedrux @Phaedrux here is a bit of information about the S42B v2.0: https://github.com/bigtreetech/BIGTREETECH-Stepper-Motor-Driver/tree/master/S42B/V2.0
                    On page 11-12 of the first document is some information about dir/step/enable.
                    The link was from https://www.reddit.com/r/BIGTREETECH/comments/l0xtgs/btt_s42b_v20_not_working_properly_what_am_i/, mentioning, that the dip switch documentation may be wrong.
                    alankilianundefined 1 Reply Last reply Reply Quote 0
                    • alankilianundefined
                      alankilian @JoergS5
                      I don't know enough to be able to help with the original poster's questions, but I have one of my own.
                      What do people think they are going to achieve using a closed-loop control board between their path creation machine (Duet) and their stepper motor?
                      My experience measuring command-vs-actual positions showed that the stepper motor positions dramatically lagged the commanded position, and the position bounced all around at the beginning and end of moves. It would have produce terrible 3D prints.
                      Do people think this is going to produce a more accurate position-control for their systems, because it's likely to not do that.
                      This system is VERY different from the one being planned where the path-generating software and the closed-loop software are both running on the same machine like the new Duet closed-loop system being tested now.
                      It would be interesting to see if anyone has gotten an external closed-loop system like this to NOT produce worse results then a properly-loaded open-loop system.
                      Gost101undefined 1 Reply Last reply Reply Quote 1
                      • Gost101undefined
                        Gost101 @alankilian
                        @alankilian @JoergS5 Does this mean you guys can help me? I have no idea as per which connector on the breadboard connects to which connector on the closed loop board.
                          https://github.com/bigtreetech/BIGTREETECH-Stepper-Motor-Driver/blob/master/S42B/V2.0/42 Stepper Motor Closed Loop Driver Control Board Manual.pdf
                          Did you take a look at the manual from that github link?
                          Have you tried connecting the step/direction/enable from the breakout board to the closed loop board yet?
                          • Gost101undefined
                            Gost101 @Phaedrux
                            @phaedrux I have, no luck.
                              alankilian @Gost101
                              @gost101 HERE'S a thread showing how to connect a different stepper driver to the expansion connector.
                              It looks like you connect step/direction/enable to the minus pins on the expansion.
                              Also, 3.3 Volts and ground.
                              Also power for the stepper motor (12V?) and ground.
                              • Gost101undefined
                                Gost101 @alankilian
                                @alankilian Which Pin connector should the GND, 5V/3.3V, & Power 12V/24V connect to on the Expansion board?
                                JoergS5undefined alankilianundefined 3 Replies Last reply Reply Quote 0
                                • JoergS5undefined
                                  JoergS5 @Gost101
                                  This post is deleted!
                                  • JoergS5undefined
                                    JoergS5 @Gost101
                                      alankilian @Gost101
                                      @gost101 Connect GND and +5 Volts from one of the two Heater connectors.
                                      You'll need to get 12 or 24 Volts from the Duet mainboard.
                                      • Gost101undefined
                                        Gost101
                                        @alankilian Is there a 12v connector on the board I can use?
                                        engikeneerundefined 1 Reply Last reply Reply Quote 0
                                        • engikeneerundefined
                                          engikeneer @Gost101
                                          @gost101 assuming you're using a 12V PSU, just take it straight from that. The Duet WiFi doesn't have an internal 12V regulator, so if you have a 24V PSU, you can only supply 24v
                                          i3 clone with a bunch of mods
                                          • Gost101undefined
                                            Gost101
                                            @alankilian Thats what I thought but wasn't entirely sure. I'll let you know if it works, when I get back home.
