    Smart Effector issue
    10
    87
    1036
    • tecno
      tecno last edited by
      Running G29 I get sporadic triggers with no Z moving, is there a way to adjust the sensitivity?
      Triggers at H height
      Any suggestions?
      achrn dc42 2 Replies Last reply Reply Quote 0
      • achrn
        achrn @tecno last edited by
        @tecno https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
        However, if it's triggering with no movement, I'm not sure that setting sensitivity is the issue, since that would imply it's triggering with no mechanical input.
        tecno 1 Reply Last reply Reply Quote 0
        • tecno
          tecno @achrn last edited by
          I get no reaction to M672 command.
          Power up 2 flashes.
          Probe input on SKRV1.4T (3 wires)
            How are you running G29 without movement?
            Here is some more detail on using M672 https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m672-program-z-probe
            • Moved from Duet Hardware and wiring by  Phaedrux Phaedrux
              dc42 administrators @tecno last edited by
              @tecno said in Smart Effector issue:
              Power up 2 flashes.
              M672 only works if there is also a command signal from the board to the Smart Effector, i.e. 4 wires.
              • tecno
                tecno @dc42 last edited by tecno
                Fixed 4 wires
                M672 S131:131 works OK with 5 flashes. Boot up 2 flashes
                But if I try M672 S105:070:255 = nothing Invalid Z probe index
                gloomyandy 1 Reply Last reply Reply Quote 0
                • gloomyandy
                  gloomyandy @tecno last edited by
                  M672 S105:070:255
                  That does not look like a valid command to me. See:
                  To program the sensor, send command M672 S105:aaa:bbb replacing aaa by the desired sensitivity and bbb by 255 - aaa. The green LED will flash 4 times if the command is accepted. When you subsequently power up the effector, the green LED will flash three times instead of twice to indicate that a custom sensitivity is being used.
                  So the 3rd value needs to be 255 minus the second value. In this case 255-70 = 185. What happens if you send: M672 S105:070:185?
                  • tecno
                    tecno @gloomyandy last edited by
                    @gloomyandy
                    • tecno
                      tecno @tecno last edited by
                      I get no where with this M672 sensitivity setting. Tried both P5 and P8 and up to 50:205 and I get sporadic jump overs.
                      Can this be my step setting?
                      M92 X80.00 Y80.00 Z80.00 E80.00
                        Is it triggering when the machine is idle, not moving?
                        If so, does it make a difference whether the hot end fan and/or print cooling fan are running?
                        • tecno
                          No fans active - no magnets on effector
                          G29 and tiggers on point where it should go down.
                          Tried now with higher µsteps
                          M92 X80.00 Y80.00 Z80.00 E80.00 ; set steps per mm
                          M350 X256 Y256 Z256 E16 I1 ; configure microstepping with interpolation
                          This gives much better result, but I think I need to adjust belts that sound to be cogging.
                          tecno dc42 2 Replies Last reply Reply Quote 0
                          • tecno
                            Still sporadic trigging, need some rest to clear my head.
                            I noticed following. when homed and issuing G29 I can observe several triggs with LED flickering.
                            This even with 55:200.
                            Also I can see push-down of bed position from 12 to 4 in outer positions.
                            Something is fishy for sure.
                              dc42 administrators @tecno last edited by dc42
                              @tecno please answer the first question in my previous post. Also tell us what M558 command you are using.
                              • tecno
                                @dc42 said in Smart Effector issue:
                                M558 P8 R0.4 C"probe+servo0" H15 F800 T1500
                                G29 and tiggers on point where it should go down. Idle = NO
                                rjenkinsgb 1 Reply Last reply Reply Quote 0
                                • rjenkinsgb
                                  rjenkinsgb @tecno last edited by
                                  @tecno What do you have in the probe G31 line?
                                  Robert J.
                                  Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                                  • tecno
                                    tecno @rjenkinsgb last edited by
                                    @rjenkinsgb
                                    G31 P180 X0 Y0 Z-0.72
                                    • tecno
                                      tecno @tecno last edited by tecno
                                      https://youtu.be/6YHxmoWgLI8
                                      M672 S131:131
                                      1/16th µstep Back to 'normal'
                                      • rjenkinsgb
                                        rjenkinsgb @tecno last edited by rjenkinsgb
                                        @tecno OK; the Z-0.72 reminds me of the smart effector I got that was faulty...
                                        The other one is incredibly sensitive, I initially set it at -0.1 but to get a correct first layer it seems better at Z0.0 !
                                        That's with all default settings.
                                        DC42 is the authority on that, though; I'm just another Duet user.
                                        Robert J.
                                          Try reducing the probing Z acceleration, using M201.1 if you are running 3.4.0RC firmware, or M201 if not. High Z acceleration combined with a high mass hot end create the same strain in the effector at the start of the probing move as nozzle contact does.
                                          • tecno
                                            M201 X1000.00 Y1000.00 Z400.00 E1000.00
                                            Slightly worse = more jump over points
                                              @tecno try even lower, e.g. 100.
                                              Also, if the green LED flashes at the end of the XY travel move rather than at the start of the probing move, increase the M558 R parameter.
                                              • tecno
                                                R1 or R2 Still same problem
                                                • tecno
                                                  No problems with fan shroud taken off.
                                                    What does the fan shroud look like when on?
                                                    • tecno
                                                      tecno @Phaedrux last edited by
                                                      @phaedrux
