    Smart Effector issue
    10
    87
    4.2k
    • tecnoundefined
      tecno @tecno
      Still some issues with false trig = does not go down but LED lights up = trig.
      How to solve this?
        When and where was it purchased?
        tecnoundefined 2 Replies Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          Warning: Skipping grid point X=40.0, Y=60.0 because Z probe cannot reach it
          37 points probed, min error -0.260, max error 0.240, mean -0.026, deviation 0.113
          Height map saved to file 0:/sys/heightmap.csv
          From where does this X=40.0, Y=60.0 coordinate originate?
          • tecnoundefined
            tecno @Phaedrux
            @phaedrux said in Smart Effector issue:
            A few weeks ago via James
            • tecnoundefined
              tecno @tecno
              @tecno said in Smart Effector issue:
              @phaedrux
              And looks like that, had to go all way up to 2500 to get reliable trig.
              Where do I set hotend offset and where to set effector offset?
              Looking from front X0/Y0 effector is to left and the hotend is a bit left too.
              Now on 3500 and the false trigs seems to be away, but need more testing to be sure.
              Also Dive height affects this now on 5mm
                dc42 administrators @tecno
                @tecno have you tried the following to eliminate the false triggering:
                • increase the R parameter in the M558 command, in case it is the previous XY move causing the spurious triggering;
                • reduce the probing acceleration, because it may be the Z acceleration at the start of the probing move that causes the spurious triggering.
                tecnoundefined 1 Reply Last reply Reply Quote 0
                • tecnoundefined
                  tecno @dc42
                  @dc42 said in Smart Effector issue:
                  Tried R0.8 still the issue +++ Will not go down to bed on all points !!!
                    Phaedrux Moderator @tecno
                    Assuming you're doing a G29 there, the grid spacing is determined by M557 in your config.g
                    https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_mesh_bed
                    • tecnoundefined
                      tecno @Phaedrux
                      Thanks, now it gets a bit clearer.
                      • Barracuda72undefined
                        Barracuda72
                        after watching our vid our prob are the short rods...but makeing the effector mount wider just makes it softer..more bending while probing. Other problen, that i had on my Delta with faulty sensivity..heatbreak came loose...so it looses lots of sensivity.
                        About your Rods...when i designed my delta some years ago there where plently of sites to calculate things like Rod lenght...max angles of rods. Maybe DC42 still have some links to such a calculator. It would be much better to have longer rods..if its ok to loose some build height. Your construction is prone to effector tilts that affects the stability while probing
                        tecnoundefined 1 Reply Last reply Reply Quote 1
                        • tecnoundefined
                          tecno @Barracuda72
                          @barracuda72 said in Smart Effector issue:
                          The rods and the adapter are original Dreammaker OverLord PRO, going back to a larger/wider effector (original adapter) made the situation better. Only trying to get this old Delta printer functional with a bit more modern parts.
                          I am in a process of building a large Delta of 1.4m height and ~550mm print diameter, Rods 610mm long directly to Smart Effector via magnets.
                          tecnoundefined Barracuda72undefined rjenkinsgbundefined 3 Replies Last reply Reply Quote 0
                          • tecnoundefined
                            tecno @tecno
                            Can somebody show me how mesh.g is written? To be run with G29
                            Stephen6309undefined 1 Reply Last reply Reply Quote 0
                            • Stephen6309undefined
                              Stephen6309 @tecno
                              @tecno This is what I use.
                              ; mesh.g
                              ; called to load/make heightmap.csv
                              M98 P"/macros/ResetBabystepping"
                              M561       ; clear any bed transform
                              while iterations < #move.axes & move.axes[iterations].visible
                                if !move.axes[iterations].homed
                                   G28
                                   break
                              G29 S1        ; load heightmap.csv
                              if result > 1 ; make if it doesn't exist
                              	G29 S0
                              That {1} isn't in it.
                              • tecnoundefined
                                tecno @Stephen6309
                                @stephen6309 said in Smart Effector issue:
                                ; mesh.g
                                     G28
                                     break
                                	G29 S0
                                Not what I was looking for, below a mesh of small circles I want to probe But do not how to write that mesh.g file.
                                  Barracuda72 @tecno
                                  @tecno take a look at https://reprap.org/wiki/Delta_geometry and theres a minimum angle of the arms..and in your vid the angles looks smaller if you probe the outermost ppoints...and then you loose all the stability..for m it looks if the arms are too short or the build diameter is too big. make a small test and just probe with a smaller build plate diameter. Use http://www.escher3d.com/pages/wizards/wizardbed.php to get a bed.g and do the probing again...and look how stable the effector might be without probing in the air
                                  • tecnoundefined
                                    tecno @Barracuda72
                                    With 80mm probe radius I have just under 30° angle on rods. So the angle is well over recommended 20° minimum.
                                    Barracuda72undefined 1 Reply Last reply Reply Quote 0
                                      Barracuda72 @tecno
                                      @tecno in the vid..when you probe the oauter points the whol effector tilts..and dont trigger...i had the same...2 towers forces the effector on the buildplate and the 3rd tower cant stabilize it...mybe its a prob because we only have mag arms...im sure you need more than 20° if you use mag arms..
                                      its easy to try a smaller bed diameter in the bed.g and make a test...
                                      Its just the same probe that i had on my 300mm Delta
                                      • tecnoundefined
                                        tecno @Barracuda72
                                        Medicine is M558 P8 R0.45 C"probe+servo0" H5 F3500 T2500
                                        • tecnoundefined
                                          tecno @tecno
                                          ; mesh.g
                                               G28
                                               break
                                          	G29 S0
                                          G29 Run file sys/mesh.g, or if that file isn't found then do G29 S0
                                          How is that file written?
                                          • achrnundefined
                                            achrn
                                            I don't think it works like that.
                                            For mesh bed compensation you can't probe at arbitrary positions, you probe on the regular grid defined in M557.
                                            Mesh.g is not for defining the probe points. As I understand it, it's for use if you have a sequence of commands you need to run to do bed probing (e.g. activate or pick up a probe).
                                            I think you may be conflating or confusing mesh bed compensation with delta automatic calibration which uses a bed.g that does contain points to probe. Which is it that you are attempting?
