    Smart Effector issue
    10
    87
    4.2k
      dc42 administrators @tecno
      @tecno try even lower, e.g. 100.
      Also, if the green LED flashes at the end of the XY travel move rather than at the start of the probing move, increase the M558 R parameter.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @dc42
        R1 or R2 Still same problem
        • tecnoundefined
          tecno @tecno
          No problems with fan shroud taken off.
            What does the fan shroud look like when on?
            • tecnoundefined
              tecno @Phaedrux
              @phaedrux
              https://youtu.be/6YHxmoWgLI8
                Ah, so quite large then.
                • tecnoundefined
                  tecno @Phaedrux
                  @phaedrux
                  Jay has been using this model without problems, so go figure.
                    Interesting. I wonder if it's a sensitivity problem then.
                    I assume it's been disassembled and reassembled already?
                    tecnoundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                    • tecnoundefined
                      tecno @Phaedrux
                      @phaedrux
                      Still as in latest picture = no duct.
                      Total weight is 84grams with 3 fans, printed in PETG.
                        jay_s_uk @Phaedrux
                        @phaedrux that duct design (which is mine) works fine for me on my smart effector v3 so i doubt thats the issue. I still think its a mechanical issue with effector tilt
                        • tecnoundefined
                          tecno @jay_s_uk
                          Have found my main issue = the printed effector adapter is way too small = too short rods.
                          Back to the drawing board!
                          • tecnoundefined
                            tecno @tecno
                            A bit larger adapter 😉
                            tecnoundefined 1 Reply Last reply Reply Quote 1
                            • tecnoundefined
                              tecno @tecno
                              One violent move and this is the result.
                              • tecnoundefined
                                tecno @tecno
                                So some days has gone and I am now trying to get the Smart Effector to work = no go!
                                New non 3D printed effector adapter (original in alu with slight modifications)
                                Area of bed 9 to 3 down to 6 can be probed G30 and 0,0 towards back about 50mm works
                                Out of that area the smart effector is not sensitive enough as the effector needs to tilt a lot before it triggers.
                                I find this a bit odd as the trigger LED on head moves. All set to default values.
                                bed.g
                                config.g
                                  Your dive speed seems to be half the recommended value. M558 F600 vs M558 F1200
                                  https://docs.duet3d.com/en/Duet3D_hardware/Accessories/Smart_Effector#configuring-firmware
                                  M558 P8 R0.8 C"probe+servo0" H10 F600 T2000
                                  M558 P8 R0.4 F1200
                                  So perhaps it's not striking with enough force to reliably trigger.
                                  • tecnoundefined
                                    tecno @Phaedrux
                                    @phaedrux
                                    And looks like that, had to go all way up to 2500 to get reliable trig.
                                    Where do I set hotend offset and where to set effector offset?
                                    Looking from front X0/Y0 effector is to left and the hotend is a bit left too.
                                    Phaedruxundefined tecnoundefined 2 Replies Last reply Reply Quote 0
                                      Phaedrux Moderator @tecno
                                      @tecno said in Smart Effector issue:
                                      I'm not sure what you mean.
                                      dc42undefined tecnoundefined 2 Replies Last reply Reply Quote 0
                                        dc42 administrators @Phaedrux
                                        FWIW we've identified a modification to the Smart Effector version 3 that improves the signal-to-noise ratio, which in turn allows you to use a higher sensitivity unless fan noise etc. prevents that. The modification is to remove capacitor C8. This can be done using a soldering iron with a bit large enough to cover both pads. Alternatively, you could use a small twist drill bit to remove a thin sliver of copper around the adjacent via that connects one end of the capacitor to the ground plane.
                                        This image is as viewed from the top of the PCB, so you need to invert it when looking at the bottom.
                                        • tecnoundefined
                                          tecno @Phaedrux
                                          @phaedrux said in Smart Effector issue:
                                          G10 P0 X-4 Y0 Z0 ; set tool 0 axis offsets
                                          G10 P0 R0 S0
                                          Fixed offset issue
                                          • tecnoundefined
                                            tecno @dc42
                                            @dc42 said in Smart Effector issue:
                                            So far during my tests no fans are used, good to know when adding fans.
