Accelerometer Usage
@tekstyle No you're right. That part is coming and hopefully will be more automated by the plugin to suggest what it should tune out, among other things.
@phaedrux oh ok. i'll wait for that in the meantime. Thank you.
@jbergene
mine says "DSH" clearly, not sure what a DH should show? Anyone? -
18.8.2021, 07:37:18 M955 P0
Accelerometer 0 type LIS3DH with orientation 20 samples at 1344Hz with 10-bit resolution, SPI frequency 2000000 -
@o_lampe Yeah maybe ill just try the DSH that arrived yesterday. that one says
2304 - DSH - YP3HC"Do you know the orientation of the purple LISD3DSH board? X Y Z
I cant find that information anywhere -
According to this picture
- positive X goes to the right
- positive Y goes to the back
- positive Z goes up
@o_lampe thank you:)
@gloomyandy I bought one from that seller. The board seems to indicate a LIS3DSH but the chip has 3CH on it which is a LIS3DH. Have you connected it up & what does the Duet report?
I bought two boards from different sellers. One should be a LIS3DH and the other a LIS3DSH. They look identical to me and both have 3CH on the chip.
The only difference is one has OED26 after the 3CH and the other OED27.
I have only connected the OED26 to the Duet so far.They both look like this on the back:
I'm assuming that the Duet will report the correct chip.
Edit: I have soldered a connector to the other one (OED27) and tested it with the Duet. Also get same message as the other one
Accelerometer 0 type LIS3DH with orientation 14 samples at 1344Hz with 10-bit resolution, SPI frequency 2000000
Hmmmpphhh!
Edit:
Further tests connecting the device to an Arduino confirm it is a LIS3DH as it returns device id = 51 (0x33). So despite it being advertised as a LIS3DSH and the pcb indicating that it is - well it isn't. So be careful when buying these folks and check the code on the chip:
3CH = LIS3DH
DSH = LIS3DSHI have ordered another one from the link given by @dc42 above. Let's see what turns up
@tekkydave Mine is marked C3H OED27. Not had chance to try it yet.
@gloomyandy It is a LIS3DH then. I have just run some tests connecting one up to an Arduino. I can only get it to communicate using an LIS3DH library.
@tekkydave Have just tested mine and RRF 3.4 seems to think it is a LIS3DH, which is a pain as I really wanted a LIS3DSH to test with (I look after the RRF STM32/LPC port). Oh well looks like I need to try and order from a different supplier.#
@tekkydave said in Accelerometer Usage:
Hmmmpphhh!
Edit:
3CH = LIS3DH
I ordered one from the seller DC42 linked to and this is what I received.
@blacksheep99 should be a LIS3DSH from the chip id of DSH.
Got my 2 today from UK and they show up as:
M955 P0 C"io3.out+io3.in"
Accelerometer 0:0 type LIS3DSH with orientation 20 samples at 1600Hz with 16-bit resolution, SPI frequency 2000000So what do I need to do next to get started? I have one for X and Z and the other for Y only.
@tecno if you have a bedslinger, then yes.
and then use the input shaper plugin to record the results -
Re ORIENTATION
As i see this is orientation I20, right?
If I flip the board so VCC will be to the right upside down is the orientation then I60 ?
How do handle this in config.g ? 2 lines ?
M955 P0 I20 C"io3.out+io3.in" ;active
;M955 P0 I60 C"io3.out+io3.in" ; not active -
@tecno Yes 60.
0 = +X, 1 = +Y, 2 = +Z, 4 = -X, 5 = -Y, 6 = -Z.
the chip's z will be pointing in printer's -z dir = 6
the chip's x will be pointing in printer's +x dir = 0 -
@tekkydave
Thanks, just want to be sure.
