    Multiple motion system
    69
    3.0k
    • Alvaundefined
      Alva @Alva
        droftarts administrators @Alva
        @Alva We're going to release 3.6.0-beta.3 in a couple of days, please retest when we release that.
        Alvaundefined 1 Reply Last reply Reply Quote 0
        • Alvaundefined
          Alva @droftarts
          @droftarts Sure will do. Thank you.
          T3P3Tonyundefined 1 Reply Last reply Reply Quote -1
            T3P3Tony administrators @Alva
            @Alva it's released:
            https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
            Testing is appreciated 🙏
            • o_lampeundefined
              o_lampe
              My understanding of the dual gcode stream is: you can open two gcode files at the same time and have a daemon.g running in the background?
              At the same time you'd have to split the config.g into two portions.
              Maybe put the U-axis specific lines in the startcode of the second stream?
              • Alvaundefined
                Alva @T3P3Tony
                @T3P3Tony Tested the above mentioned testing procedure and got the same error as 3.6.0.beta2 + 5.
                • Alvaundefined
                  Alva @o_lampe
                  @o_lampe My requirement is to utilize the unused axes during printing, with their movement controlled via daemon.g and triggered by a flag. My understanding of multiple motion systems is that the unused axes should be accessible to the other motion system. However, the error I am encountering indicates that the unused axes are still being treated as part of the motion system responsible for the print job.
                  • Alvaundefined
                    Alva @Alva
                    Any updates about this topic? My observation is 3.6.0-beta2+3 worked , but after that it is broken. Thank you
                      @Alva I've asked @dc42 to have a look at the issue.
                      • Alvaundefined
                        Alva @droftarts
                        @droftarts Okay , 🙏 thank you.
                        • Alvaundefined
                          Alva @Alva
                          @Alva @dc42 sorry for writing again, but will there be fix regarding this topic in the next version?
                          dwuk3dundefined 1 Reply Last reply Reply Quote 0
                          • T3P3Tonyundefined T3P3Tony referenced this topic
                          • dwuk3dundefined
                            dwuk3d @Alva
                            @Alva I think I am getting the same issue as you - in 3.5.4 I can access my U axis in Motion system 1 ok - but not in any of the 3.6.0 beta versions I have tried.
                            The problems I am getting though the 3.5.4 is that the synchronisation isn't working - with either M598 and M400 don't seem to work. Plus also I can't seem to extend the length of the queue with M595 beyond 5 entries.
                            • dwuk3dundefined
                              dwuk3d @dwuk3d
                              @Alva Update - Just managed to get it working in 3.6.0b4 - by surrounding all references to the U axis in M596 P1 - including in the homing macro's
                              M598 still not working for me though -
                              plus in my case I am finding a connected Mini5+ board runs slow in 3.6.0b vs 3.5.4 - so I have left that board at 3.5.4
                              jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                                jay_s_uk @dwuk3d
                                @dwuk mixing 3.5.4 and 3.6b4 based boards, with the amount of changes that have happened between the two, is a really bad idea
                                • gloomyandyundefined
                                  gloomyandy @dwuk3d
                                  @dwuk said in Multiple motion system:
                                  Can you provide more details on that? What exactly is slow?
                                  • dwuk3dundefined
                                    dwuk3d @gloomyandy
                                    @gloomyandy The U&V axis don't react instantly when you press the +1/+10 etc. button - there seems to be a small delay.
                                    Also when homing the U Axis - it is a two pass process - normally the first hit happens, the tool head immediately moves back, and then has its' second attempt, but with 3.6.0 again there is a slight delay.
                                    The the Mini5+ board is on 3.5.4 there is no noticeable delay.
                                    If there isn't any obvious answer I will make a short video at some point to demonstrate the difference.
                                    dwuk3dundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                    • dwuk3dundefined
                                      dwuk3d @jay_s_uk
                                      @jay_s_uk Yes I am sure you are right. I am not really seeing any advantage in 3.6.0b4 over 3.5.4 at the moment - so will probably revert the whole lot back to 3.5.4 - as all 3.6.0 is unusable for me.
                                      • dwuk3dundefined
                                        dwuk3d @dwuk3d
                                        @gloomyandy Just realised this is @Alva's thread - if you look at my one you will see a lot more detail of the 'slowness' problem
                                          jay_s_uk @dwuk3d
                                          @dwuk if you're doing any remapping of axes after movement in 3.5.4 that's unusable too.
                                          You'll notice a difference when you come to print something as the movement code is way better in 3.6, especially pressure advance and input shaping
                                            jay_s_uk @dwuk3d
                                            @dwuk the out of sync/delay issues with a mainboard in expansion mode has been fixed internally. Don't know if a build has been made available
