    Multiple motion system
    69
    2.9k
      droftarts administrators @Alva
      @Alva We're going to release 3.6.0-beta.3 in a couple of days, please retest when we release that.
      Alvaundefined 1 Reply Last reply Reply Quote 0
      • Alvaundefined
        Alva @droftarts
        @droftarts Sure will do. Thank you.
        T3P3Tonyundefined 1 Reply Last reply Reply Quote -1
          T3P3Tony administrators @Alva
          @Alva it's released:
          https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
          Testing is appreciated 🙏
          • o_lampeundefined
            o_lampe
            My understanding of the dual gcode stream is: you can open two gcode files at the same time and have a daemon.g running in the background?
            At the same time you'd have to split the config.g into two portions.
            Maybe put the U-axis specific lines in the startcode of the second stream?
            • Alvaundefined
              Alva @T3P3Tony
              @T3P3Tony Tested the above mentioned testing procedure and got the same error as 3.6.0.beta2 + 5.
              • Alvaundefined
                Alva @o_lampe
                @o_lampe My requirement is to utilize the unused axes during printing, with their movement controlled via daemon.g and triggered by a flag. My understanding of multiple motion systems is that the unused axes should be accessible to the other motion system. However, the error I am encountering indicates that the unused axes are still being treated as part of the motion system responsible for the print job.
                • Alvaundefined
                  Alva @Alva
                  Any updates about this topic? My observation is 3.6.0-beta2+3 worked , but after that it is broken. Thank you
                    @Alva I've asked @dc42 to have a look at the issue.
                    • Alvaundefined
                      Alva @droftarts
                      @droftarts Okay , 🙏 thank you.
                      • Alvaundefined
                        Alva @Alva
                        @Alva @dc42 sorry for writing again, but will there be fix regarding this topic in the next version?
                        dwuk3dundefined 1 Reply Last reply Reply Quote 0
                        • T3P3Tonyundefined T3P3Tony referenced this topic
                        • dwuk3dundefined
                          dwuk3d @Alva
                          @Alva I think I am getting the same issue as you - in 3.5.4 I can access my U axis in Motion system 1 ok - but not in any of the 3.6.0 beta versions I have tried.
                          The problems I am getting though the 3.5.4 is that the synchronisation isn't working - with either M598 and M400 don't seem to work. Plus also I can't seem to extend the length of the queue with M595 beyond 5 entries.
                          • dwuk3dundefined
                            dwuk3d @dwuk3d
                            @Alva Update - Just managed to get it working in 3.6.0b4 - by surrounding all references to the U axis in M596 P1 - including in the homing macro's
                            M598 still not working for me though -
                            plus in my case I am finding a connected Mini5+ board runs slow in 3.6.0b vs 3.5.4 - so I have left that board at 3.5.4
                            jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                              jay_s_uk @dwuk3d
                              @dwuk mixing 3.5.4 and 3.6b4 based boards, with the amount of changes that have happened between the two, is a really bad idea
                              • gloomyandyundefined
                                gloomyandy @dwuk3d
                                @dwuk said in Multiple motion system:
                                Can you provide more details on that? What exactly is slow?
                                • dwuk3dundefined
                                  dwuk3d @gloomyandy
                                  @gloomyandy The U&V axis don't react instantly when you press the +1/+10 etc. button - there seems to be a small delay.
                                  Also when homing the U Axis - it is a two pass process - normally the first hit happens, the tool head immediately moves back, and then has its' second attempt, but with 3.6.0 again there is a slight delay.
                                  The the Mini5+ board is on 3.5.4 there is no noticeable delay.
                                  If there isn't any obvious answer I will make a short video at some point to demonstrate the difference.
                                  dwuk3dundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                  • dwuk3dundefined
                                    dwuk3d @jay_s_uk
                                    @jay_s_uk Yes I am sure you are right. I am not really seeing any advantage in 3.6.0b4 over 3.5.4 at the moment - so will probably revert the whole lot back to 3.5.4 - as all 3.6.0 is unusable for me.
                                    • dwuk3dundefined
                                      dwuk3d @dwuk3d
                                      @gloomyandy Just realised this is @Alva's thread - if you look at my one you will see a lot more detail of the 'slowness' problem
                                        jay_s_uk @dwuk3d
                                        @dwuk if you're doing any remapping of axes after movement in 3.5.4 that's unusable too.
                                        You'll notice a difference when you come to print something as the movement code is way better in 3.6, especially pressure advance and input shaping
                                          jay_s_uk @dwuk3d
                                          @dwuk the out of sync/delay issues with a mainboard in expansion mode has been fixed internally. Don't know if a build has been made available
                                          • dwuk3dundefined
                                            dwuk3d @jay_s_uk
                                            @jay_s_uk Great - I was imagining it was some sort of comms issue - happy to test out the fix.
