    What would you build if you were starting again now?
    99
    11.4k
    • peter247undefined
      peter247 @dc42
      I'm not sure what I would rebuilt , but what I know is , Gentleman we can rebuilt it , we have the technology , we make it better , stronger , faster.
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      • o_lampeundefined
        o_lampe @droftarts
        @droftarts said in What would you build if you were starting again now?:
        Most machines still only use 4 or 5 drivers
        A big plus for Deltas here, they only need 3 steppers for the whole motion system, where others use 3 steppers only for Z-axis.
        opentoideasundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
        • opentoideasundefined
          opentoideas @o_lampe
          @o_lampe
          Delta is tempting my main issue is spending the money on the materials to do it right in the first place which I know is the best way to go but I suspect I will probably end up trying to start with a working machine then upgrade it to (hopefully) make it close to what I want.
          I was having a look around and if I got something like an Anycubic Predator it should at least work to start with and it seems to be at least a solid frame. I could then slowly spend the money I should have spent in the first place to make it better. the electronics are rubbish but then seeing as I am here its no surprise how to resolve that problem and then linear rails, rods and smart effector might make it the basis for a good machine in the end...
          the biggest problem is the initial outlay. from the Blog DC42 posted while his machine I have no doubt is far superior I cant justify £1k initial outlay but a few hundred then a few hundred more LOL I might get away with sneaking that past the wife!
          • deckingmanundefined
            deckingman @o_lampe
            @o_lampe said in What would you build if you were starting again now?:
            I can't buy that argument. People might choose to use multiple Z motors but that's a personal choice and a single motor driving multiple screws is a perfectly viable solution, even with a large heavy build plate. So whether it be Cartesian, or CoreXY then 3 motors are perfectly viable for X, Y and Z. My personal preference is CoreXY because for all moves other than 45 degree infill, then both motors contribute to motion. And for those 45 degree moves which use a single motor, there is an increase in available torque due to the gearing effect of the belt path.
            o_lampeundefined 1 Reply Last reply Reply Quote 2
            • PaulHewundefined
              PaulHew @zapta
              @zapta May I reccomend you use the single MGN12 rail for X, unless you already have, using dual MGN9's were causing a torsion.
              The 'clicky' probe as opposed to the inductive, or there is a MGN12 BLT mount for the AfterBurner.
              I was going to rebuild mine with a 1LC and mini5+ and the expansion board, but lost faith with the gantry.
              As I mentioned above, the gantry is doing too much.X/Y/Z on rubber bands! 😉
              Hope yours works well.
              RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
              Voron 2.4 disassembled..... Waiting for the RailCore Mini....
              • zaptaundefined
                zapta @dc42
                @dc42 said in What would you build if you were starting again now?:
                The Duet 3 Mini + 2-driver expansion doesn't use CAN, the expansion is a daughter board.
                That's a good combination, thanks, I will look into it, and indeed direct interface between the MCU and all the 7 drivers. My original plan was to first build a stock Voron (Spider + SBC) and then mod it but may go directly with Duet.
                Any reason why not using the Mini+2 for Voron 2.4?
                pixelpieperundefined 1 Reply Last reply Reply Quote 0
                • zaptaundefined
                  zapta @droftarts
                  While there is a market for standalone boards with 7+ drivers, it's not a big one. Most machines still only use 4 or 5 drivers.
                  The Chinese vendor address it by using plugged in driver modules. This way you pay only for what you use. On the down side, it looks ghetto.
                  @PaulHew, I already assembled the X with two stock rails, but will look for mods once the base configuration will work.
                  • pixelpieperundefined
                    pixelpieper @zapta
                    @zapta I run this very combination together with a 1LC V1.1 toolboard, works extremely well.
                    Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
                    Voron V0.250 / Duet 2 Maestro
                    zaptaundefined 1 Reply Last reply Reply Quote 0
                      pixelpieper @zapta
                      @zapta a TMC2209 is about 1.5$ on digikey if you buy large enough quantities and can be SMD assembled while soldering the stepstick headers is fairly expensive - I doubt there are huge savings by keeping the drivers of the PCB.
                      • o_lampeundefined
                        o_lampe @deckingman
                        @deckingman said in What would you build if you were starting again now?:
                        Point taken; we don't have to use more than one Z-driver. But the real life tells a different story.
                        Some even use two X and Y motors, it must be an unknown virus 😷
                          deckingman @o_lampe
                          It has been known for people to fit extruders on additional gantries on Delta printers, such that they follow the Z axis. So even Delta style printers are not immune from the "additional motor virus". 🙂
                          dc42undefined 1 Reply Last reply Reply Quote 1
                            dc42 administrators @deckingman
                            It is because there are several types of machines that need more than the usual number of motors that we decided to make the Duet 3 Mini capable of driving 7 motors before needing CAN expansion. We originally designed it for 8 motors using a 3-driver daughter board, but we ran out of microcontroller pins to control the 8th motor.
                            However, on a Voron or similar machine with direct drive extruder, using a CAN-connected tool board on the print head to connect the extruder motor, heater, thermistor, hot end fan, print cooling fan, Z probe, X endstop and accelerometer saves a lot of wires.
                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                            • DIY-O-Sphereundefined
                              DIY-O-Sphere @dc42
                              With the restriction that the voron (2.4) uses an inductive sensor, and that is currently not yet supported.
                              This is exactly the point at which I gave a friend the recommendation for toolboard and mini and he now has to lay 3 additional wires.
                              (UTC+1)
                                dc42 administrators @DIY-O-Sphere
                                @diy-o-sphere said in What would you build if you were starting again now?:
                                I can think of no reason why you can't connect an inductive sensor to a tool board, in the same way that you would connect one to a Duet 3 main board.
                                  opentoideas
                                  so what are the inherent strengths and weaknesses of the current options?
                                  Delta - tall for the build height reliable and proven looks like multi head printing is tricky though not impossible
                                  CoreXY - strong structure but quite large footprint for the build area. long belts and multiple idlers "may" introduce errors as it wears
                                  CroXY - looks the strongest again bigger footprint for the build area penalty for strength is the greater moving mass and complexity of multiple motors
                                  these are the few things I have noticed but they are less important than reliability and print quality. speed is always welcome but subservient to print quality
                                  sebkritikelundefined 1 Reply Last reply Reply Quote 0
                                    DIY-O-Sphere @dc42
                                    https://duet3d.dozuki.com/Wiki/Duet_3_firmware_configuration_limitations#Section_Semi_permanent_limitations
                                    "Z probes connected to expansion or tool boards are limited to types 8 and 9."
                                    Or have I misunderstood something?
                                    Edit:
                                    Got it...Typ8 is similar to Typ5,,,should work....
                                    (UTC+1)
                                    pixelpieperundefined 1 Reply Last reply Reply Quote 1
                                    • sebkritikelundefined
                                      sebkritikel @opentoideas
                                      @opentoideas said in What would you build if you were starting again now?:
                                      Instead of a CoreXY, why not an equal volume 'cartesian' (not to be confused with a bed-slinger) printer?
                                      • Arguably simpler belt and drive component routing (X moves in X, Y in Y, Z in Z)
                                      • Shorter belt segments (lengths are only ~2x a single axis length)
                                      • Equally strong/rigid structure
                                      • Marginally heavier gantry moving in the Y directions (since you're moving the X axis stepper)
                                      Large(ish?) IDEX - 6HC, 1HCL
                                      Stratasys Dimension 1200es to 6HC Conversion
                                      opentoideasundefined 1 Reply Last reply Reply Quote 0
                                        opentoideas @sebkritikel
                                        @sebkritikel
                                        No reason, I would put that into the CroXY camp though as the geometry is more of a match just without the second arm but its semantics.
                                        I was just going for the general machine types as there are many different designs in each camp but allong similar principles that i would think the strengths and weaknesses would hopefully match.
                                        Like I said those were just my simple and uneducated views and by no means exhaustive or even correct, just a starting point and I am hoping those with knowledge and experience can explain what the benefits and weaknesses are as they see them.
                                        The more I have thought about it the more I think about DC42's mention that his delta has been running years with the least trouble and while there are many many designs that work in complex and interesting ways the delta at least in terms of mechanical components is simple tried and tested....
                                        This led me to ask the question why all these new super complex machines? Why are they so popular when the delta just works?
                                        fcwiltundefined dc42undefined deckingmanundefined 3 Replies Last reply Reply Quote 0
                                        • fcwiltundefined
                                          fcwilt @opentoideas
                                          Well I don't consider my printers "super complex". Yes, one has 6 steppers (1 X, 2 Y, 3Z) but it does what I want it to. I have no multiple tool printers.
                                          I started with three mini-deltas and then got a classic Cartesian, an FT5. The FT5 print quality was so much better that I gave up trying to get the deltas to generate the prints I wanted and disposed of them.
                                            pixelpieper @DIY-O-Sphere
                                            @diy-o-sphere I have an inductive Superpinda on my V2 connected to the 1LC, works beautifully.
